Rubbing sound
08.05.2020 14:11 # 1
Today, a sound came from the right side of the car ... A high-pitched rubbing sound ... As if a piece of metal was rubbing on a metal floor. I suspect the discs. But it continues again ... I suspect the shock absorber, I sat in it, a friend was loaded, the right front shock absorber did not sound ... I felt the torpedo was not cut again. ?thank you..
08.05.2020 14:11 # 2
If a friend helps, I would be very happy.
08.05.2020 14:11 # 3
Carmania
Did you look at the brake pads? so if he's done he can make a sound
08.05.2020 14:11 # 4
behzat
When the pad is finished, it will sound like that Approve
08.05.2020 14:11 # 5
kocvizyon
Look at the sister who can make it from the steering pump
08.05.2020 14:11 # 6
This is not the sound of the buzz I'm talking about.
There is no extra sound on the brakes when the brakes are pressed, but ... it shouldn't be about the honeymoon.
08.05.2020 14:11 # 7
hasimayaz
Is the sound symmetrical with anything? wheel rotation, steering wheel rotation, vehicle spring or engine speed?
08.05.2020 14:11 # 8
look at the right shock absorber upper ball, no problem, if the pump is not right on the steering pump, hold the brake while the vehicle is moving, press the brake if there is a sudden pull to the right or left, either from the disc or the brake pad.
08.05.2020 14:11 # 9
my master, only the sound increases in the spring ... the sound increases in the cysts ... the sound in the albanian stone increases ... it decreases in the asphalt.
08.05.2020 14:11 # 10
peugeotefe
Is your vehicle 206?
08.05.2020 14:11 # 11
My vehicle 2002 model 307 xs
08.05.2020 14:11 # 12
peugeotefe
can make from ball joint or suspension rod
08.05.2020 14:11 # 13
As if I found the source of the sound ... The sound first started when I went to my school in the village. I went to the village today, it started a little bit again. I said it came from the front, I have examined it before today. The sound comes from the right front fender 80%. Right front fender is a little loose car. When I pushed it a little, it sounds loud. Ordn also ... I opened the hood ... I removed the plastic next to the wiper ... I found the fender screw ... I don't know if the screw is tight but not seated, it moves and it sounds like I said ... I squeezed the machine oil but it did not go ... WD40 Does it work if I buy rust remover?
