Rubbing noise coming from front right side
25.07.2021 01:18 # 1
Ofkao
Hello friends, about 1 month ago, I bought a Peugeot 306 automatic 2000 model car. Since I bought it, there is a rubbing sound in the front, especially in 1 and 2 gears, I can hear it a lot, especially in 1 and 2 gears. and where can you recommend for a solid Peugeot service
The car is idling, at first there is no sound, after it starts to move, it seems like two parts are rubbing against each other
I need your help
25.07.2021 04:48 # 2
muzzy35
You will probably hear the differential at high revs.
25.07.2021 09:55 # 3
Ofkao
Do you have the same sound?
25.07.2021 15:53 # 4
muzzy35
Yes, unfortunately I have it too, but it's not something that puts it on the road, and it costs too much because it is one with the gearbox, so the gearbox had to go down, so the master said, don't waste money now, God forbid, if something happens with the gearbox in the future, if we have to lower it, we will change it or as I said, the sound is so loud that it can be heard at 1200 rpm. He said come if it happens
Let me even describe the sound like this, just like two irons rubbing against each other, like sharpening a knife. As the speed increases, the sound increases as the speed increases. If you still want it, drive a transmission master to see if it's the same reason.
25.07.2021 21:22 # 5
Pejjj0.206
Did the Wheel take a hit?
25.07.2021 21:32 # 6
Pejjj0.206
When the blow is taken, the hub is warped. It sounds like a throat and throat Du I had it too Master Tahir used to fix it on the lathe, now there is no sound
26.07.2021 07:22 # 7
Ofkao
I bought the wheels brand new 20 days ago I think it can't be
