Rubbing Noise at the Wheel
08.05.2020 18:51 # 1
seyhanak
Friends 206 car has been rubbing the steering wheel left and right for 1-2 days. It sounds as if the steering plastic touches and rubs somewhere. I checked the steering hydraulics enough. There is no hardening or abnormality in the steering wheel.
Does anyone have experience in this regard?
08.05.2020 18:51 # 2
ibanez_022
A sound called vıııjjj, the pump feels weak, so the pump must be dismantled and go to the maintenance, and I have the same problem. the voice will not increase said the master use it like this
08.05.2020 18:51 # 3
qqyyxx
check the mats first, it may rub against the steering column. If the sound is coming from the steering hub, it could possibly be a problem with the airbag winding.
08.05.2020 18:51 # 4
seyhanak
There is no problem with friends at the mat. The steering wheel was not dismantled recently. According to the Saah, the sound seemed to decrease in the afternoon. There was no intervention. Why might that sound?
08.05.2020 18:51 # 5
sporcu
Notice where the sound comes from. I have a similar situation. The steering is in full or over-breaking situations. Not the steering pump's moaning sound. A rubbing sound that rhythmically changes according to the speed of the wheel. As if the hood rubbed the wheel. As a result of the trials I made, I noticed that the sound was cut when I pressed the clutch. As far as I can read, even some have gone to axle change due to similar sounds. I will examine a little more. I am thinking of driving by connecting an action camera to the inside of both wheels at a convenient time. If we go to the masters of the dormitory, they come to change from the rear bonnet cover to the front. Let your wheel press flat.
