Rubbing buzzing sound after 307 1600 cycles.
08.05.2020 19:08 # 1
Faruk
Hello friends
In my car, sound like rubbing hum, which started at 1500-1600 rpm and ended at 3000 rpm.
cuts the clutch pressure.
not always.
He did not do it on the way to the service yesterday, so I could not show it to the master.
Now I am a little away from the service. It is important that this sound may cause something.
no change in traction.
Faruk 2015-03-07 12:11:57
08.05.2020 19:08 # 2
Faruk
Is there anyone who can help with this?
thanks.
08.05.2020 19:08 # 3
themurat54
I think a similar topic was opened recently
08.05.2020 19:08 # 4
Efe-Pojo
If the car was idling, it would cut the clutch and hit the clutch but I would not know if it was doing on the way. I think there is something about the engine then. can be from straps. the problem is always hiding when you go to the master, I know that you show that feeling to the master, it is normal, so I know it is normal but it improved when you came to it :)
08.05.2020 19:08 # 5
Faruk
[QUOTE = Efe-Pöjo] I would not know if the car stopped idling when it was pressed to clutch, but if it was on the way, I would know it. I think there is something about the engine then. can be from straps. The problem is always hiding when you go to the master, I know that you show that emotion to the master, it is normal, so I know it is normal, but it got better when it came to you.
Yes, you are right Smile
08.05.2020 19:08 # 6
Faruk
[QUOTE = themurat54] I think a similar topic has been opened recently [/ QUOTE]
thanks.
I have not seen a topic like this in the near future.
08.05.2020 19:08 # 7
Faruk
thanks to the interested friends.
I went to my private service today.
He said from the front center axle ball.
something more and the gearbox oil was done in 1.5 hours including workmanship kept 150 rubles. thank goodness this time 307 me Smile
Faruk 2015-03-07 12:13:47
08.05.2020 19:08 # 8
kuantum
[QUOTE = Farouk]
something more and the gearbox oil was done in 1.5 hours including workmanship kept 150 rubles. thank goodness this time 307 me Smile [/ QUOTE]
What is the front middle axle ball? Every wheel I know has axle balls, but there is no wheel in the middle?
My vehicle also has a 307 SW 2006 model. Circuit-linked humming rises, automatic transmission. When the gear shifts, it stops instantly, but when it is about to shift into new gear, the roar is increasing, can it be related?
08.05.2020 19:08 # 9
Faruk
[QUOTE = quantum] [QUOTE = Farouk]
yes it was from the middle axle ball.
mine was the same as what you told.
As the speed increased, the sound increased, and when I changed gears, mine cut it by pressing the clutch.
service road seems to you too :)
Faruk 2015-03-09 09:55:28
