Rotting pipe
08.05.2020 20:42 # 1
x571
Hi
I think there is a rotting pipe part in the air filter. The heat coming from the radiator refuted there over time. What piece is this piece? which part name should you search for? Would it be a problem if I used it for a few days until the piece came?
08.05.2020 20:42 # 2
talip206
Air filter hose. I wouldn't recommend using it this way. Because dirty dusty air enters. In addition, since the vehicle cannot adjust the air ratio well, it may be a poor mixture and it may shake at idle. Wrap the worst place with something like that where you go but don't put off too much.
08.05.2020 20:42 # 3
you should change it as soon as possible. As our friend said, you can have problems. Not an expensive piece, brother. 20 tl
08.05.2020 20:42 # 4
GokhaN
wrap the hose with something until the air cleaner hose gets the last outlet part, as dirt206 says @ talip206
08.05.2020 20:42 # 5
x571
[QUOTE = sonerkyl ] [/ QUOTE]
[QUOTE = suitor206 ] [/ QUOTE]
The part I showed in the video is not fully seated. how do i fix it? The clamped part is hard plastic.
x571 2017-12-26 09:01:52
