Rolland Garros Cycle Cutter Hk
08.05.2020 19:02 # 1
carpediem_ksk
Is there a revolver in the 206s and above, especially in the 1.6 90 Rolland Garros?
08.05.2020 19:02 # 2
monalos
Nothing in the car, I tried it overnight, I saw 70 but I did not enter it, I said no, I left the research :)
08.05.2020 19:02 # 3
koray.turan
I have it in my car
08.05.2020 19:02 # 4
muro_60
I know they all have it, there are 99 models 206 in our friend.
08.05.2020 19:02 # 5
carpediem_ksk
I pressed 5500 I didn't dare any more
08.05.2020 19:02 # 6
muro_60
[QUOTE = carpediem_ksk] I pressed 5500 I didn't dare any more [/ QUOTE] you will not press it :)) press the engine when the engine is hot do not try the cold engine :))
08.05.2020 19:02 # 7
fætih
99 exists at 1.6xt.
08.05.2020 19:02 # 8
monalos
Why don't I have it either? 60 did not enter 60. I don't see 70.
08.05.2020 19:02 # 9
Barut
2. Put into gear about 95 enters the cutter, not in 5th gear but :)
08.05.2020 19:02 # 10
cafein___
2004 1.6 110 gr does not cut whatever God gave :)
of course we do not recommend ..
08.05.2020 19:02 # 11
herry
When the engine is warm, idle root gas enters the cutter like 6.5 - 7 thousand revolutions. Notice that if the lpg is in the car, the cutter may be disabled.
08.05.2020 19:02 # 12
carpediem_ksk
My gasoline vehicle alone brings 7,000 revolutions at once, can the pistons jump out of the crankshaft gear or waste, so would the high revs fail immediately?
08.05.2020 19:02 # 13
herry
[QUOTE = carpediem_ksk] My gasoline vehicle alone brings 7,000 revolutions at once, can the pistons jump from the crankshaft gear or waste, so does the high rpm immediately fail the car [/ QUOTE]
If the cycle enters the circuit breaker, there will be no problem. If the cutter is canceled, it is likely to experience trouble.
08.05.2020 19:02 # 14
BG307
Cuts at 6500 rpm.
08.05.2020 19:02 # 15
carpediem_ksk
What if he didn't cut
Peugeot Forums - Peugeot Fan Club © 2025
FromOwner.co.uk — Buy & Sell Directly from Owners in the UK. No dealers. No commissions. Just from owners.
