rolanti
08.05.2020 16:49 # 1
mehmet6667
friends mrb, my car is 2000 model 206 xr 1.4 8v gasoline.friendly 30 seconds after starting the car, wrecked, i.e. the car is shaking, idle badly, lpg got last week, this problem disappears when the car got into the gas, they changed the spark plugs, they cleaned the throttle but it didn't seem it got worse, what do you think could be the main reason ..
08.05.2020 16:49 # 2
mehmet6667
Is there no one to help .. ..
08.05.2020 16:49 # 3
sosyete_60
I had the same problem from me, but I was doing it both in gas and gas, I did not understand that you did it only in gasoline, but my problem is solved as follows: There is a green color on the engine, the one goes to the idling engine and adjusts it according to the water temperature, and I changed this excuse, all the problems disappeared but my it was both in gas and gas
08.05.2020 16:49 # 4
mehmet6667
mehmet6667 2012-05-29 12:33:35
08.05.2020 16:49 # 5
mehmet6667
Thank you for those whose brother is not interested, I will try what you said
08.05.2020 16:49 # 6
mehmet6667
brother, what is the name of that client?
08.05.2020 16:49 # 7
mehmet6667
[QUOTE = sosyete_60]
I had the same problem from me, but I was doing it both in gas and gas, I did not understand that you did it only in gasoline, but my problem is solved as follows: There is a green color on the engine that goes to the idling engine and adjusts it according to the water temperature and I have changed this custom. the problems have disappeared but I was making both gas and gas
& nbsp;
brother, what is the name of that green sender?
08.05.2020 16:49 # 8
ekinoks44
If you have a problem and & nbsp; write this & & nbsp; in a few hours & nbsp; search and can't find a solution, how does it make sense for my site? Everyone on the site is not online at the same time .. It is necessary to be a little patient, not only for this subject, but always ..
08.05.2020 16:49 # 9
volkanbalik
My friend has an idle engine, I would recommend you to clean it, look at the throttle and check the oxygen sensor.
08.05.2020 16:49 # 10
mehmet6667
[QUOTE = volkanbalik] buddy vehicle has an idle engine, the solution would be shorter if it had been done in the gas I would recommend you to have it looked at the throttle and have the oxygen sensor checked.
regards.
When the vehicle passes the gas on gas, it cuts, but naturally, because it does so much in gas, there is a little reflection in gas, so it does very little in the gas. Thank you very much for the information you gave my brother, God bless you.
08.05.2020 16:49 # 11
falan
[QUOTE = mehmet6667] brother what will be the name of that sender, what is it? >
08.05.2020 16:49 # 12
sosyete_60
Yes, green sender, look at you already, you see, there is a brown color, that fan has a green bidet.
08.05.2020 16:49 # 13
mehmet6667
I haven't tried anything left, I got the gal butterfly cleaned and got it done, but it has been 2 months since I bought a futile vehicle, but if it goes like this, I can't get close to the peugeot car, what it would be wrong to find, somehow, engine idle in the idle.
08.05.2020 16:49 # 14
sosyete_60
have you changed the sender
08.05.2020 16:49 # 15
mehmet6667
I said he could be from the client, he laughed at the master, and they changed upon my insistence, but they said it was impossible to be from him, they said it had nothing to do with him from afar.
08.05.2020 16:49 # 16
mehmet6667
[QUOTE = sosyete_60] Did you change the sender
said I could be from the sender, he laughed at the master and they changed my insistence, but they said it was impossible to be from him They said it had nothing to do with it from afar. Reviews
08.05.2020 16:49 # 17
mehmet6667
[QUOTE = mehmet6667] [QUOTE = socyete_60] Did you change the client
I said it could be from the client, he laughed at the master and I insist they changed, but they said it was impossible to be from him, they said it had nothing to do with it from afar.
so no bro ..
08.05.2020 16:49 # 18
falan
the same problem happened with me today .. I said to buy gas on LPG .. the vehicle suddenly & nbsp; Meanwhile, I said I will open the bidet air conditioner & nbsp; this time it went badly & nbsp; idle started to play between 500-1200 then I bought it again & nbsp; has improved .. I'm surprised what we'll do ..
08.05.2020 16:49 # 19
ufuk91
the idle is low enough to stop when I first open it (but usually it stops when I run it first) my problem started after lpg maintenance, I said I would clean the throttle myself, the problem increased even more, the money got stuck again.
08.05.2020 16:49 # 20
ttaylanaa
Get past this problem if you encountered it after having lpg installed, the problem may be caused by the lpg system. I said I have a problem with gasoline, no lpg, but that does not mean it is not caused by lpg.
& nbsp;
My vehicle does not notice a slight flickering lpg-gasoline at idle and there was a P0171 error. I say without exaggeration, I used it in gasoline without passing 500 km to any LPG, neither my fault lamp went out, nor the vehicle shake. I went to the authorized lpg service, they made a setting for 15 minutes. My malfunction lamp & nbsp; It was 300 km & nbsp; not burned, it also went through the vibration on the vehicle & nbsp; & nbsp;
adjusted the Lpg system, but the vehicle's & nbsp; operation changed. Actually I couldn't make sense ...
ttaylanaa 2012-05-30 13:37:51
Page : / 2
