rolanti
08.05.2020 15:44 # 1
gerten
Friends I have a 2005 model peugeot 206 petrol car
When I wasted on the way at 2000 -3000 rpm on the road, the speed indicator comes very slowly, so to speak, it comes to 1200 revolutions, it goes down to 1000-900 revolutions after stopping there for a while.
It used to be a division, it used to be down to 900 cycles
What could be the problem guys
08.05.2020 15:44 # 2
It may be from the idle valve, my friend ... but the masters will help you with this problem ..
08.05.2020 15:44 # 3
gerten
Could it have anything to do with a butterfly?
08.05.2020 15:44 # 4
I have the same problem. Idling falls very slowly when I take my foot off the gas. LPG spark plug was reduced but not over. It still continues. I did not fall on it because it did not seem very important.
08.05.2020 15:44 # 5
gerten
someone who might have been involved with the lambda sensor
08.05.2020 15:44 # 6
Muhammet CAKIR
it is probably one of the idle balls
08.05.2020 15:44 # 7
It could be anything. There are so many possibilities. It is best to have it connected to the computer and see the error codes.
08.05.2020 15:44 # 8
There is no error code. It does not fail. Somewhere the lamp does not light up. But as he descends he descends like an old man. I do not care much about the other, like the young boy of 18 when leaving the god.
08.05.2020 15:44 # 9
Muhammet CAKIR
the same thing happens when you press the gas when the vehicle is idle
08.05.2020 15:44 # 10
[QUOTE = Menderes] No error code. It does not fail. Somewhere the lamp does not light up. But as he descends he descends like an old man. I do not care much about the other, like the young boy of 18 when leaving the god. [/ QUOTE]
Do you peel when you start it, or do you peel because the light does not burn? Because the error code does not necessarily have to be lit for the engine to go down. But the opposite is not true. In other words, if the engine malfunction light comes on, there is an error code.
Koliva 2011-07-02 12:08:34
08.05.2020 15:44 # 11
I'm telling you, I'm telling you. They said nothing was written. But I did not look at it personally. I haven't tried it in idle. But I guess it's the same.
08.05.2020 15:44 # 12
Clean the throttle.
08.05.2020 15:44 # 13
[QUOTE = Menderes] I'm telling you to tell me. They said nothing was written. But I did not look at it personally. I haven't tried it in idle. But I guess it's the same. [/ QUOTE]
So, is your gas peg wired? Could he be hanging out?
08.05.2020 15:44 # 14
I do not know. As I said, it was not fortunate to fall on it. I hope I will see if I can go to Kismet, I hope. I will even share it if I shoot the video. But is it an important problem if it is not through the wire of the accelerator? You've got it in my head now.
08.05.2020 15:44 # 15
[QUOTE = Menderes] I do not know. As I said, it was not fortunate to fall on it. I hope I will see if I can go to Kismet, I hope. I will even share it if I shoot the video. But is it an important problem if it is not through the wire of the accelerator? You've got it in my head now. [/ QUOTE]
The possibility that the gas wire may remain stuck came to my mind for now. In addition, the throat butterfly may be contaminated, as your friends mentioned. Idle speed controler, which controls the throttle valve, may be contaminated. These are the ones that come to my mind for now.
08.05.2020 15:44 # 16
What do you call idle speed control?
Something like the idling engine?
08.05.2020 15:44 # 17
[QUOTE = meander]
Something like the idling engine? [/ QUOTE]
I translated the English directly into Turkish, maybe it is the idle engine.
The picture below:
Koliva 2011-07-02 20:34:27
08.05.2020 15:44 # 18
peugeot murat
The rollers make late fall from the electrovalve valve. When the rotation sensor is turned on the air conditioner or when it is started in the morning, it turns the engine to the choke position and balances the relay according to the temperature information of the water.
08.05.2020 15:44 # 19
ose
[QUOTE = koliva] [QUOTE = Meander]
The picture below:
[/ QUOTE] There is another electronic component connected to the throat butterfly similar to this directly on the goose butterfly. Or is he doing the duty that I call? Koliva 2011-07-03 08:53:06
08.05.2020 15:44 # 20
I think I got it wrong Gülme
I did not say that the problem is precisely this part. I said this piece among the possibilities, but there are still other possibilities. So don't just focus on this piece. For example, have you looked or looked at the gas wire? This part is used to adjust the position of the throttle according to the position of the accelerator pedal. Its location is number 2 in the figure below. In the picture on the left is the stepper motor that translates the small gear on the right.
