Roland garros have 88 hp
08.05.2020 21:00 # 1
muratk19
hello pejo lovers I just joined you yesterday 2001 model
1.6 I have Roland garros, but I think this vehicle is 109 HP, while 88 hp is written on the license (66.1 kW).
08.05.2020 21:00 # 2
boruc
I have known my teacher 90 hp more.
The image of the engine of 90 with the engine of 110 is different.
The engine in the link below is 1.6 16v 109 HP engine
Fitters 2018-09-02 00:16:32
08.05.2020 21:00 # 3
muratk19
how can we add photos here
08.05.2020 21:00 # 4
muratk19
https://photos.app.goo.gl/7qdvsbmdozjrwvvo6
08.05.2020 21:00 # 5
boruc
[QUOTE = muratk19] https://photos.app.goo.gl/7qdVSBmDoZJRWVVo6 [/ QUOTE]
Picture does not open hodja
08.05.2020 21:00 # 6
Ufuk_64
If you entered the coma from the owner, maybe you could find the result, I looked at you for you, but here one or both did not give correct information. 600 410 444 88 hp .... 599 659 451 110 hp ... 600 218 101 buda 110 hp but the engine is the same as I gave it first. The so-called last two ads are 110 hp but the engines are different (one is lying). I think the first announcement 88 hp 2.lan 110 hp result is now you find ..
08.05.2020 21:00 # 7
RP393
hello, look at the announcement 109 HP in the system, it turns out so. 1.6 gasoline 206s have 8v 90 HP engine with TU5JP - coded until the end of 2000. Since 2001, 16v 109 HP engine with TU5JP4 code has been used.
You can tell these codes from the picture by searching on Google which engine is in your vehicle. Smile
Edit: I looked at the picture you uploaded. 8v 90 HP motor. Your vehicle is end of 2000 production and 2001 market.
RP393 2018-09-02 22:22:25
