rod, shock absorber, rod end hk. help...
08.05.2020 14:14 # 1
My friends vehicle 307 1.6 xs. On the rough roads, the cobblestone roads and the pits, there is a loud sound like "warmth". As a result, net rot or shock absorber diodes. The shock absorber remained. The reason for this sound is the shock absorber. I am too pimpy, I am financially distressed, but I can't sleep comfortably without interrupting this sound. What do you suggest me to do? show the way ... Ağlama
let's 2010-04-28 01:36:40
08.05.2020 14:14 # 2
mahmutq
the president has the same problem with mine, but if you find tr mistake and make it happen, it will be the same one month later.
reno taurus goes to our roads and uses it as a chicken cake
Don't worry, where do you go? Gülme
08.05.2020 14:14 # 3
Does it affect from cold-heat in amotrisers? So it's okay, but because it is cold, motor, car, etc., do you get a heat when it warms up ... I went to get a friend in the city center. like..
08.05.2020 14:14 # 4
okankrgz
As I said when I had 106 quicksilver, there were a lot of clicks, my upgrade wedges were finished, I had changed it, the sound was cut off .. maybe you can only save it with a wedge if there is no problem with the shock absorber, I guess it does not exceed 50 TL.
08.05.2020 14:14 # 5
I took the car to the service today;
Rear crossmember bushings
Axle seal
They said that the right side engine ear should be replaced ,,
There was no urgency in the engine ear, we canceled it.
250 TL including 1 lt gearbox oil and labor (negotiable result)
They said that the voice will be cut, let's see if we see it tomorrow, hopefully it will stop.
08.05.2020 14:14 # 6
Can you write down exactly what these parts do?
For signature intention; If this car is mine, it does not leave me on the road, if it is waiting for me in front of my house like lions, I have to fulfill my duty as well ... My goal is to clean my invidiual friend. ...
