Rocker door paint color or code
08.05.2020 21:28 # 1
kaan206
What exactly is the color I will buy a paint for the rocker cover paint, or can it even write the color code? kaan206 2020-02-23 19:53:59
08.05.2020 21:28 # 2
x571
I also think about disassembling and painting, but should I use torque when installing? How many torques should we tighten? Would it be normal gray spray?
08.05.2020 21:28 # 3
I swear I did not see that often, except some of torque with turkey rektefeci ever actually. it will be any dark gray paint but definitely buy heat resistant paint. hard to find the same color code. some painters have devices that tell the color code, but where will you find them.
08.05.2020 21:28 # 4
kaan206
you are right ... but i will not paint it completely. It is best to go to the painter and buy a little bit of dark gray paint and touch up. It is good to be dark gray, even if the stripped places look brown, not keeping the color tone.
08.05.2020 21:28 # 5
kaan206
[QUOTE = x571] I think I can disassemble and paint it as well but do I need to use torque when installing it? How many torques should we tighten? Would it be normal gray spray?
In fact, if tightening with torque is too tight, it can be skewed
But they also say what will happen to the two neighborhoods, such as no trotting, etc. I renewed the rocker plastic seal and it didn't take the master to insert and tighten it!
08.05.2020 21:28 # 6
x571
[QUOTE = sonerkyl] swear I did not see that often, except some of torque with turkey rektefeci ever actually. it will be any dark gray paint but definitely buy heat resistant paint. hard to find the same color code. some painters have devices that tell the color code, but where will you find them. [/ QUOTE]
I'll do it :)) but I can't find the torque. The vehicle is old. The service booklets of the new ones are always on the Internet. The old ones are hard to find. He will either take it out of the chest he has or tell a friend who knows it.
08.05.2020 21:28 # 7
x571
[QUOTE = kaan206] [QUOTE = x571] I am thinking of removing it and painting it as well but do I need to use torque when installing it? How many torques should we tighten? Would it be normal gray spray?
What did you give as workmanship? It will be cheaper and easier to take to the master, but I also like to do it myself. Even if I can, there is no Turkish source to shoot videos.
08.05.2020 21:28 # 8
kaan206
He said whatever he got out of his heart Smile
08.05.2020 21:28 # 9
talip206
The rocker cap has no torque. Since it is not a screw used there, it is a blind nut, and it stops when it ends.
If anyone wants to disassemble it, don't be afraid to take it off for 5 minutes.
I will not know the color code, but the element in the places selling paint can give it a similar tone when you see it. The color is a mixture of dark gray and a little dark green.
talip206 2020-02-24 21:52:43
08.05.2020 21:28 # 10
kaan206
teacher the torque of the cap is not already
But make sure each screw has a certain torque value.
kaan206 2020-03-23 10:08:19
