Ripple in 307 automatic initial start-up
08.05.2020 20:27 # 1
ben_erhan
Hello friends
My vehicle had a week of antipollution malfunction and the coil had changed .. The vehicle's cycle fluctuates when I first started the car and stopped. Then it goes over 10 and returns to normal. then it comes to its normal position.
Facing something like that? Who knows the solution?
Thanks
08.05.2020 20:27 # 2
throttle adaptation then re-adjust if lpg is available.
08.05.2020 20:27 # 3
ben_erhan
How is this done? Need to be cleaned?
08.05.2020 20:27 # 4
ben_erhan
[QUOTE = sonerkyl] throttle adaptation then reset if lpg is available. [/ QUOTE]
Soner bro, I removed the throat butterfly and cleaned it with a lining spray .. metal ear was black stained and cleaned. I do not know, the master just dismantled and cleaned up .. idling when the car started. Under 10 .. like 7 .. when the air conditioner turns on or plugs (D) or (R) it rises a little but it does not exceed 10 or above. 8. Or 9, but it does happen. How should it normally be? How can I improve if my idling is weak ... I feel a slight vibration if the car is in the gear while waiting in the lights when the air conditioner is on. As I pull my foot from the brake or give gas, it gets better.
08.05.2020 20:27 # 5
ben_erhan
I used the tool in a gasoline for a while .. it did not cause any problems .. the problem was said from lpg .. I made the lpg setting.
08.05.2020 20:27 # 6
talip206
[QUOTE = ben_erhan] I used the tool for a while .. it did not have any problems .. the problem was called from lpg .. I made the lpg setting.
Since it runs with rich mixture in the first run, it will be around 1000 cycles. When the engine gets a little warm, it will be around 900 rpm after a while. Idling ripple May not be felt as the combustion value of gasoline is good. Do not get stuck in very minor plays. When it is time for maintenance, you can replace the spark plug, air filter, LPG filter and make observations. There is also an idler sensor on the throat butterfly, it is useful to remove it and clean it with lining spray. Because as the throat butterfly gets dirty, the room gets dirty. talip206 2017-09-08 18:21:39
08.05.2020 20:27 # 7
ben_erhan
This time I will replace the spark plugs. Let's see what happens.
