Ripple at 307 idle
08.05.2020 14:53 # 1
ispinoze
Greetings,
The vehicle fluctuates when the engine is cold. I guess this situation had not been before. Though the weather has just started to cool down, but is it normal in this cold to work this way? I do not know. In the previous treatment, the throat butterfly or something was cleared. After this butterfly cleaning, gas adaptation adjustment was made. Does anyone know about this? Or is the fluctuation in every 307 users when the engine is cold? Vehicle lpg + gasoline 2005 307 xt otm.
08.05.2020 14:53 # 2
Walla, I do not have a ripple, no junk, hobby. Why do not the people who wear lpg do not stop the problems, sometimes they do not do anything other than darkening the 307.
08.05.2020 14:53 # 3
xMEGANx
both in the gasoline vehicle ?? : S garippppp
08.05.2020 14:53 # 4
Does the cold do this fluctuation before I get to the LPG or will I switch to LPG? First of all, you need to understand it, LPM, event ???
Turn off the LPG and use it completely with gasoline if it does it before going to LPG. Is there any problem with this problem or does it pass when it gets hot?
If the ego is doing it to the LPG, it will be cut only when the engine reaches this degree? Let's take a look at these words ...
08.05.2020 14:53 # 5
BAHTIYAR
While all European countries are defending the LPG, why are you putting the crime on LPG when almost all of the cars in the UK are LPG? I have been using it for 4 months.
08.05.2020 14:53 # 6
bayelektronik
I do not have 307 gasoline idling problems with gasoline.
08.05.2020 14:53 # 7
ispinoze
[QUOTE = EmRaH] there is no ripple wiping in my walla, I don't have anything other than stapling 307. / quote]
This is how good my friend. Whether I use the vehicle with LPG, I take it, or I use gasoline to whom! Kim is evil 307. Maybe you know a different situation. Good master, find it if you put it with your hand. How many masters are there in the country so that you can match them well. Ours doesn't know what to do. I'm investigating myself.
08.05.2020 14:53 # 8
ispinoze
[QUOTE = cecoli] Does the cold do this fluctuation before going to lpg or will I switch to lpg? First of all, you need to understand it, LPM, event ???
Thanks for the answer ... Same thing in gas, in LPG. I made a few attempts. There is no problem when you go 5.6 km. Even open the air conditioner to the end, again no problem at idle. As the friend said, it may be caused by clearing the throat butterfly and not adapting it.
08.05.2020 14:53 # 9
bayelektronik
teacher, I think it may be the throat butterfly itself. It may be the maf sensor. The maf sensor is the sensor that adjusts the air flow according to the temperature.
08.05.2020 14:53 # 10
ispinoze
I think [QUOTE = bayelektronik] my teacher may be in the throat butterfly. May be in the maf sensor. The maf sensor is the sensor that adjusts the air flow according to the temperature.
Could be. Let's have a look at that part. thanks...
