rims and lsatic selection
08.05.2020 15:11 # 1
forewer_fb
hi friends What are your rim and tire suggestions for 1.6 306? original dimensions 185 "65" 14
If I wear 16 wheels, is the car too tired, your brand and model suggestions as a tire ... respect ...
08.05.2020 15:11 # 2
You can wear 185 60 15.
08.05.2020 15:11 # 3
[QUOTE = berkaygr] 185 60 You can wear 15. [/ QUOTE]
It can be 185 60 15. but in general it is equivalent to 195 55 15 cap, which is a more sedate scale ... This is the best score of 306. already this 306 gti is also used ...
16 "is the most appropriate size is 195 50 16. There are rare but this is the most equivalent in 16 minutes. They usually wear 195 45 16, but the original captain will be small and 45 will have a hard cheek. 50 cheeks are better ...
the cecol 2011-03-24 22:17:07
08.05.2020 15:11 # 4
forewer_fb
[QUOTE = cecoli] [QUOTE = berkaygr] 185 60 You can wear 15. [/ QUOTE]
Would it be a lot of difference in the vehicle traction if I put it as 15 "195 55 would be better?
The wheels I want to buy are 206 rc 5 arms but not original.
08.05.2020 15:11 # 5
dukenukem82
take the rim weight by measuring if you want it
08.05.2020 15:11 # 6
[QUOTE = forewer_fb] [QUOTE = cecoli] [QUOTE = berkaygr] 185 60 You can wear 15. [/ QUOTE]
If you wear the 16 "size I said, it will not be as sensible as it is a difference in weight. The appearance of the 16" rim will be nice. but it will cost and be higher.
Let me remind you of the rim offset. the rim that he is talking about might be 24-25 offset. If possible, look for a 15 "rim with 18 offset.
I think there are 650 "for 15" replicas. I think there are 16 "replicas for 700.
08.05.2020 15:11 # 7
forewer_fb
The price I say will be like 16 wheels. If I bought 195 50 16 tires, it will probably be nice ...
08.05.2020 15:11 # 8
650 pounds price is 16 "for the rim is very good ... do not do the offset heat behind the ear. I see some rims.
08.05.2020 15:11 # 9
forewer_fb
[QUOTE = cecol of]
yes you are right I will not ignore the offset issue, thanks for your comments ...
08.05.2020 15:11 # 10
xdesign
Brother 15 "I have 195 50 15 rims with offset. Clean. Tires Bridgestone. If you are interested at pm ...
08.05.2020 15:11 # 11
rgree
easy to buy. i bought a peugeot 106 xr. the size of the tires 185/55/14 Are these tire sizes suitable for my car? thanks
08.05.2020 15:11 # 12
serkan67
16 "and the tire 195/45/16 is ideal, I just got it installed, the wheels are 4x108 meat 20-25, not up.
08.05.2020 15:11 # 13
[QUOTE = rgree] let it be easy. I bought a peugeot 106 xr. Are the tires size 185/55/14 suitable for my tire? Thank you [/ QUOTE]
106 gti use this size but I'm not completely sure of yours. Usually, there is a sticker on the edge of the door of the sofor or the hinges. or writes in the user manual. If you can not reach, you can look at peugeot.com ...
08.05.2020 15:11 # 14
[QUOTE = serkan67] 16 "and the tire 195/45/16 is ideal, I just got it installed, get the rims 4x108 and 20-25, not up. I made that mistake. The issue is out. etc vs [/ QUOTE]
nice brother if you introduce yourself to our forum rules as required, we will get to know you ...
08.05.2020 15:11 # 15
boraa
serkan67 you join my union from zonguldak contest Clown
08.05.2020 15:11 # 16
[QUOTE = boraa] serkan67 you join the contest from zonguldak contest Clown [/ QUOTE]
Antalya has written to the friend position, but I guess you didn't see it. basically you can write there too ...
