rim tire for pejo 206
08.05.2020 19:44 # 1
byildiz
hello friends pejo 206 or 195.50.15 rim tire rubbing do you use any emergency information please
08.05.2020 19:44 # 2
Ahmetaltan
I use. It doesn't make rubbing or something.
08.05.2020 19:44 # 3
byildiz
If I ride in 5 people, it wouldn't be a problem.
08.05.2020 19:44 # 4
ALLEX
[QUOTE = byildiz] If I ride it in 5 people, there will be no problems in the back, there were 17 rims, I'm rubbing, I pull it to 15 [/ QUOTE]
I do not think that it will be a problem at 15. When the winter tires are bought, the prices vary according to the sizes.
08.05.2020 19:44 # 5
samet206
It uses 206 rims that usually use 15 rims for tire sizes, but it does not rub, but still, depending on the car's flatness and friction related to the rim's value. You can use tires, if you can, I find 185/55/15 sizes more suitable.
08.05.2020 19:44 # 6
byildiz
I said the arrival of the 5 people :) 195 50 15 would be rubbing in terms of width, so when we go to the country, we bring the back closer to the ground.
08.05.2020 19:44 # 7
aslanaft
[QUOTE = byildiz] I said the arrival of 5 people :) 195 50 15 do we rub in terms of width, so when we go home, we bring the back closer to the ground.
mrb brother has 206 in me 195/50/15 does not kurt and looks nice in the view because the cheek is thin
08.05.2020 19:44 # 8
byildiz
Thanks guys I will be joining today
08.05.2020 19:44 # 9
acabuco
[QUOTE = byildiz] Thanks guys I will be joining today [/ QUOTE]
Are you going to give the 14s and buy 15, my teacher, do you trade or buy 15 from zero?
08.05.2020 19:44 # 10
OguzhanKucuk61
I said not to open a new one when there is a ready topic. I know the original size of 206 hbs is 175/65 14. My vehicle is fitted with 206 Sedan and 175/65 14 but the ORIGINAL value 185/65 written inside the door 14. I think the tire in the near future. But instead of pulling to the original dimensions, 195/55/15 can be attached without breaking the total diameter. But my current tire diameter is 2% smaller than it should be and I think the size of the new rim tire Time 205/55 15, which is 2% larger than the original (185/65 14). Sorry it was a bit complicated. What should I do?
08.05.2020 19:44 # 11
samet206
205/55/15 size, I don't need to keep the base wide enough for 15 rims in 206. I think Max 195 base or 185 base is suitable.Also I would like to say that the comfort decreases when the original size is changed from 65 sidewall to 50 sidewall tire. consider it.
08.05.2020 19:44 # 12
OguzhanKucuk61
I think the wide base will help because I am not satisfied with the handling and braking distance, but I am also aware that it will increase my fuel, which is not very good at the same time, to some extent. I'm thinking of doing at least 195 55 15 But let's see. Thank you to my samet206 friend for his ideas and comments
08.05.2020 19:44 # 13
byildiz
I wore 195 50 15, I changed it because of riding the new 205 base rider 205 40 17. I think it is nice.
08.05.2020 19:44 # 14
OguzhanKucuk61
The hoods of the Hb ones are narrower, so the 205 base will be quite wide yes 195 seems more logical
08.05.2020 19:44 # 15
seiko35
Use 195/46/16 brother bro my wheels are super image like this
08.05.2020 19:44 # 16
OguzhanKucuk61
Thank you seco, this is also a preference, but both 16 wheels are expensive and I feel like going over the rim on 45 cheeks :)
08.05.2020 19:44 # 17
seiko35
The decision is solid, because my brother is wide
08.05.2020 19:44 # 18
GokhaN
the http://forum.peugeotturkey.com/forum_posts.asp?tıd=39115&title=206-jant-lastik-secim-kilavuz
08.05.2020 19:44 # 19
OguzhanKucuk61
Thank you very much detailed information. 195 55 15 seems to be the most logical
