rim selection help
08.05.2020 17:27 # 1
angarya0061
If I put a 175/70/14 rim tire on my 106 xr vehicle, it would be a kurtme anyway.
08.05.2020 17:27 # 2
KenBlockJR
rubbing happens. It rubs even 175/65/14.
Does not rub 165/65/14 or 185/55/14
08.05.2020 17:27 # 3
GokhaN
If you use it without a spring, use 175 65 14.
If you are going to use the bow, you can use 185 55 14.
08.05.2020 17:27 # 4
angarya0061
If I use 3.5 bows, I will use the arbya only, I will wear a 5 cm bow, but it will not be 185 55 14 do not rub, but do not grin?
08.05.2020 17:27 # 5
rockwaryumm
[QUOTE = angarya0061] If I use 3.5 bows, I will use the arbya only, I will wear a 5 cm bow, but it will not be 185 55 14 do not rub, do not grin? [/ QUOTE]
What kind of grin will he make? Smile I even changed my car to 195 45 14, now I look at the front as a team, but it is necessary to use it carefully. Smile
08.05.2020 17:27 # 6
angarya0061
I will get 185 55 14, then the construction will not rub and I will wear 3,5 springs only enough for sure :)
08.05.2020 17:27 # 7
rockwaryumm
[QUOTE = angarya0061] 185 55 14 will not build, then it will not rub. 3,5 spring will be enough just forward:) [/ QUOTE]
Well, my vehicle is 195 45 14 in front, 185 55 14 in back, rubbing hasn't even been with 5 people and 3 people over 100 kilos. Exhaust rubbing it apart LOL see the lowness according to him you will understand
08.05.2020 17:27 # 8
angarya0061
teacher your car 3 door bnm car 106 xr 5 door will be bigger than yours: D
08.05.2020 17:27 # 9
rockwaryumm
[QUOTE = angarya0061] teacher your car is 3 doors bnm car 106 xr 5 doors will be bigger than us: D [/ QUOTE]
I thought the hoods are the same, I thought LOL I think there is no difference (my personal opinion, but I am fearless about these issues. LOL ) Of course, we have to ask those who experience it. But when I saw the wearer with xr a 185 55 14 gti rim, I don't know if they did any additional action.
08.05.2020 17:27 # 10
angarya0061
There are necessarily the gti rim, which makes the hood opened, because I have worn 175 70 13 snow tires, even in winter, when I turn the friction right to the left, I am very cautious :)
08.05.2020 17:27 # 11
rockwaryumm
Isn't it because of her cheek? After all, you shrink the cheek Confused Of course, my personal opinion is that I am just trying to find the answer I am looking for by asking questions.
08.05.2020 17:27 # 12
angarya0061
Exactly how I will try to look like 185 55 14
08.05.2020 17:27 # 13
rockwaryumm
[QUOTE = angarya0061] the same way now 185 55 14 how do I try to look like it will not work: D [/ QUOTE]
Well, if you are from Ankara, you can say mine try it but you are not LOL I would say directly because I read your name as angayra and thought it was from ankara LOL But if you are coming, I can gladly check it. LOL
08.05.2020 17:27 # 14
angarya0061
If I find a way from Ankara to istbuldan, I would believe: If I find it on the side of D ist andolu, a few people will be fine ...
08.05.2020 17:27 # 15
angarya0061
http://www.sahibinden.com/ilan/yedek-parca-aksesuar-donanim-tuning-jant-lastik-jant-lastik-takimlari-peugeot-106-gti-jant-lastik-114133672/detay how do you think of a couple teacher
08.05.2020 17:27 # 16
rockwaryumm
[QUOTE = angarya0061] http://www.sahibinden.com/ilan/yedek-parca-aksesuar-donanim-tuning-jant-lastik-jant-lastik-takimlari-peugeot-106-gti-jant-lastik-114133672/detay I found a couple how do you think my teacher [/ QUOTE]
If there is no broken repair or something, take a wheel. Watch out for the tire event, if you need to re-tire, I think it will cost more than zero rim.
08.05.2020 17:27 # 17
angarya0061
I will be careful, thank you for your help :)
08.05.2020 17:27 # 18
angarya0061
I ask you one more thing before I go. If I buy you 13 rim gti wheels, how do I think if I wear 3.5 rims, can I find 13 gti rims?
08.05.2020 17:27 # 19
rockwaryumm
[QUOTE = angarya0061] I ask you one more thing before I go, if I buy you 13 rim gti rim, 3.5 how do I wear a spring, I don't know if I don't wear 14 rim tire, can I find 13 gti rim?
