rim selection
08.05.2020 18:42 # 1
netweb
I will buy a steel rim for 1.4 diesel 307, I have a 15 inch hair rim. NetWeb 2014-07-15 19:55:37
08.05.2020 18:42 # 2
samet206
The wheel bolt is a separate subject, the diameter of the wheel and the wheel bolt are completely different. Even if the size of steel rims is installed, a difference can be felt. Visually smaller than 307.
samet206 2014-07-16 00:09:13
08.05.2020 18:42 # 3
reality59
I use 16 "Ariane Wheels, lassa impetus revo + 205-55-16 advice either stay at 15" or 17 "Challenger Wheels I recommend you to install :)
08.05.2020 18:42 # 4
KIZILASLAN
[QUOTE = reality59] I use 16 "Ariane Wheels, I recommend lassa impetus revo + 205-55-16 either stay at 15" or 17 "Challenger Wheels:) [/ QUOTE] What is the problem in 16?
08.05.2020 18:42 # 5
GokhaN
[QUOTE = netweb] I will buy a steel rim for 1.4 diesel 307, there is a 15 inch hair rim on 16 inches. Do you think the traction will decrease and the fuel will increase. What happens to me? Or will the same effect be effective without any situation?
I will tell you the simplest example, remove 15 hair wheels and put on 15 aluminum wheels. If you have a traction drop, you will not understand. motor small case large
08.05.2020 18:42 # 6
reality59
It doesn't fill the car, it stands empty
08.05.2020 18:42 # 7
kizilkan89
Tire sizes are also important in this regard, but my brother will not feel so much to understand the 1 inch of fuel and the strength you have lost.
