rim repair
08.05.2020 19:48 # 1
x571
After hitting the pavement, the rim and tire are as follows. I will replace the tire, but do I need to repair the small trapezoid on the rim? How many TL repairs go? other tires michelin 4 seasons tire should i buy again 4 seasons tire?
x571 2016-05-13 19:31:29
08.05.2020 19:48 # 2
Karacocuk24
The rim correction is around 30 TL. If the tire is in the same condition with other tires, that is, the tread depth does not appear, but if the old tire has cracks and wear and tear as a year, you can change 4 tires, or even a sharp stone may appear in the other tires.
08.05.2020 19:48 # 3
x571
Yes, the tires are old, but the tread depth is not troublesome. Would it be a problem if one of the front tires is old and new? Or if the tire pattern is different, would it be a problem?
08.05.2020 19:48 # 4
x571
I guess I'm the only one with tire problems in the forum :)
08.05.2020 19:48 # 5
outlaw
NO NEW REQUIRED WHEEL REQUIRES WHEEL COMFORTABLE HOW MANY PARALLY MATERIAL
BEING 4 SAME PATTERN ON THE TIRE NEEDS TO CREATE A DIFFICULTY IN THE VISA ...
08.05.2020 19:48 # 6
omer_tarsus
How is the spare tire and rim
08.05.2020 19:48 # 7
x571
[QUOTE = outlaw] WHEEL REQUIRES REMOTE NEW BUY HEAD GET COMFORTABLE HOW MONEY MATERIAL
My friend, don't underestimate it. If you buy steel, it starts from 250 TL, if you buy a sheet, it starts from 80 TL. If it is too little for you, let me give my iban number.
x571 2016-05-14 23:26:01
08.05.2020 19:48 # 8
x571
[QUOTE = ömer_tarsus]
they are perfect. they are used for the first time.
08.05.2020 19:48 # 9
Goktug306
The same thing happened to me the other day. It is not worth getting.
08.05.2020 19:48 # 10
outlaw
[QUOTE = x571] [QUOTE = outlaw] WHEEL REQUIRED REPAIRED NEW BUY HEAD COMFORTABLE HOW PARITY MATERIAL
I HAVE VERY WHEEL TIRE GIFTS IN TIME
IF YOU CAN'T BUY 80 TL BOX RIM FOR YOUR CAR, IT IS ...
WE HAVE 1000 TL TO OIL FILTER MAINTENANCE, IF IT IS NOT NECESSARY.
08.05.2020 19:48 # 11
ssakyel
Get well, there is nothing on the rim, straighten and use. I'm very pleased.
08.05.2020 19:48 # 12
omer_tarsus
[QUOTE = x571] [QUOTE = ömer_tarsus]
In this case, if I were, I would fix the rim, I would buy a tire up to 50 TL and used it as a spare tire. After all, when the tire bursts, we go and lay it down immediately.
08.05.2020 19:48 # 13
x571
[QUOTE = ömer_tarsus] [QUOTE = x571] [QUOTE = ömer_tarsus]
Thank you. I'll do it like this. they were straightening the rim smoothly. Only that end was crooked. I have used michelin spare tire which has not been used for 7-8 years and I use it. I think I will beat the front tires in winter or something. I will buy falken or nokian. I looked at the tests, the braking distance on wet ground is class A in these tires. Other familiar tires are generally class B, Petlas, matador, duro, syron and brands such as C brake class. I don't think of choosing them either.
08.05.2020 19:48 # 14
x571
[QUOTE = ssakyel] Get well, there is nothing on the rim, use straighten. Most of the rims on the remover can also be ripped and straightened rims. Although the tire rear and front are different, the traces of the opposite ones must be the same. So two tires will handle you. I 200 I bought tl bar for two, I'm very happy.
Thank you, for how many years I have removed the backup michelin i have never used. It was the first time to use it. I will prefer the brands in the up message for the tire. they are successful in brake tests. they seem to be taken.
