Rim painting. Pictures on page 1
Homepage » PEUGEOT MODIFIED PLATFORM » How To
08.05.2020 16:00 # 1
Rim painting
Our material
- paint
-acrylic lining
-acrylic paint varnish
- Thick sandpaper. Medium sandpaper. Fine sandpaper.
-paste
-hardener
-oilcloth
-sponge spatula vs tools :)
Rim painting ImageShack.us
Guys, we separated our rims from oil from dirt in the first stage and we cleaned them with ozone.
Burak Bülbül ImageShack.us
Sanding and puttying process ...
After sanding and paste, I applied 2 coats of primer with the first layer and half an hour.
rim painting ImageShack.us
I applied the first coat of paint from the back of the liner.
In the painting process, I threw it on the second floor ... the second floor in the picture now is thrown paint.
After finishing the painting process, we leave our rim to the sun to dry.
And after finishing two coats of paint as a last treatment, I applied vernigide as a last treatment :)
burak.bülbül 2011-08-24 21:50:40
08.05.2020 16:00 # 2
okan4037
What will you paint with? spraying? my supercharged ..
If you paint it, you can not return to its original color, you should consider some things ... or I would say professional paint
08.05.2020 16:00 # 3
I will spray it myself, but I don't know what to do ....
I do not know whether I will get sandpaper first, polish, varnish, varnish, I do not know, but I do not understand English conversations.
08.05.2020 16:00 # 4
http://www.usengecadam.com/nasil-boyanir/araba-janti-video_56fb7a684.html
Tell me I found something, but since he painted it black, the process is different.
08.05.2020 16:00 # 5
g-demir
You have to scratch the existing paint. Sandpaper is ample but fine. then paint. but I don't know what kind of paint
08.05.2020 16:00 # 6
I know the sanding process but what thickness sandpaper do you need first ???
08.05.2020 16:00 # 7
2 Quality Spray Paint and 1 Sanding .... :) Done ... Alkış ibrahim aslan 2011-08-16 00:07:51
08.05.2020 16:00 # 8
g-demir
[QUOTE = ibrahim Aslan] 2 Pieces of Quality Spray Paint and 1 Piece of Sandpaper .... :) Done ... Alkış [/ QUOTE]
let's not stop? Confused
08.05.2020 16:00 # 9
34sea45
I guess it is 320 cm or water sanding scratch in order to leave a scratch, then a nice cleaning, a good drying, painting in a clean area, I think it is necessary not to make any discharge while painting.
08.05.2020 16:00 # 10
yes, I did a lot of research and took photos and shared them on the forums.
First, I clean the wheels beautifully. Then, after I take thick sanding paste, I wet the scratches with watery sanding, then sanding again from the back of the liner, then I apply the primer after 3 coats :)
this event will last 3 days :)
08.05.2020 16:00 # 11
34sea45
be late or be beautiful, be blessed :)
08.05.2020 16:00 # 12
God bless tomorrow, let's see if I transfer photos to work here.
08.05.2020 16:00 # 13
34sea45
If you buy me, I will copy the rims of the castle.
08.05.2020 16:00 # 14
See my friend painted himself as I said 2 pieces of Spray 1 piece of Sandpaper ....
08.05.2020 16:00 # 15
QUOTATION
Maybe the process I did on my previous rims can guide you ... In addition, my old rims are the same model as yours and I painted it in a black tone. Smiley Actually, the process is very easy ... At first, we are applying watery thick sandpaper ... Then we pass it with fine sandpaper (so that the scratches left by the thick sandpaper are not obvious when the paint is applied) ... Later paint and varnish ... Until today I painted rims on it and always applied this process ... I and my friends have been using it for a long time ... Buddha is a frame from my old rims ...
08.05.2020 16:00 # 16
hakann83
God give it easy
08.05.2020 16:00 # 17
I said I will start today, there were guests, I could not start ...
but I took my old tires out of the tank ...
now my first job is to separate the tire from the rim :)
Even the tire makers need to take the 25 lira tire off the rim.
08.05.2020 16:00 # 18
[QUOTE = afaruk307]
QUOTATION
Thank you for your interest, I will do as the man says, now on the rims in this picture, thank you 14 of the rim in me for your sharing :)
08.05.2020 16:00 # 19
[QUOTE = Burak.Bülbül] [QUOTE = afaruk307]
QUOTATION
Sharing is good Gülme
08.05.2020 16:00 # 20
One of Our Members Has Been Painted, Burak If You Find The Topic And Try To Get Help From It ...
Page : / 4
