rim painting
08.05.2020 16:16 # 1
lau5
hello everyone
anybody have the idea and knowledge of how to paint the wheels in this gloss :)
08.05.2020 16:16 # 2
34sea45
The gloss varies according to the quality of the polish you use regarding the polish that is applied after the paint.
08.05.2020 16:16 # 3
lau5
So is there a nice polish you know?
08.05.2020 16:16 # 4
Engin Tepe
You know how to add brightness, but how you will paint will spray over time if you do it with spray paint.
08.05.2020 16:16 # 5
lau5
Well, I don't think that if I polish it on a certain white spray right now, it will be so smooth. I wonder what I need to paint and polish with it?
08.05.2020 16:16 # 6
34sea45
First you need to clean your wheels with water sandpaper, then you will apply 2 or 3 coats of paint without spraying or spraying, and then you will get full polish.
08.05.2020 16:16 # 7
pachito
a little & nbsp; advice & nbsp; after sanding the rim 1 & nbsp; I recommend you to coat the floor, at least the floor will be smooth. This kind of painting before & nbsp; If you haven't, I suggest you try on another object, otherwise there will be discharge and you won't like it. I recommend you to buy spray & nbsp; from the series, which are not matte but shiny (for example, your akcal is divided into 2 as both matte and glossy spray).
08.05.2020 16:16 # 8
Could it be glossy coating instead of rim painting?
08.05.2020 16:16 # 9
Engin Tepe
For example carbon: D
08.05.2020 16:16 # 10
cerci07
[QUOTE = Engin Tepe] For example carbon: D [/ QUOTE]
carbon fiber effect is hard, not every person can do it
