RIM AND TIRE SIZE CHOICE HELP PLEASE
08.05.2020 17:12 # 1
umut_25
Hello Friends.
I just joined you and I really need your suggestions and opinions on this topic. Thank you to all friends who have already answered.
& nbsp I will have a 206 Quiksilver this weekend. The vehicle has a 17 "strange rim and tire. When I took it to the service to have the car checked, they said that this tire and rim came too much to this car. Also, it would be healthier for me to replace the front springs. As soon as I get the car, I will replace the front springs and the tire rim assembly. I am wearing the original springs. I am confused alone on the side of the tire rim. I read the topics in the forum but I could not find a satisfactory answer. So I opened the topic again.
Road Grip + Brake Distance + Comfort + Style and Fuel Consumption
This is what I expect from the tire and rim group in order. & nbsp;
Help I'm waiting for your name.
08.05.2020 17:12 # 2
Barut
I think it is called Şirokko from the factory rim to the vehicle, I think the wind rose is available at 206 cc, the same rim size is 15 inches. knowledgeable friends will write their more enlightening views.
08.05.2020 17:12 # 3
umut_25
So let's assume I bought a 16 "rim. What would be the ideal size of the tire?
08.05.2020 17:12 # 4
Bugra
08.05.2020 17:12 # 5
Bugra
the wheels in the picture above are the size of sirocco 15` rim tires 195/55/15 tire size.
08.05.2020 17:12 # 6
umut_25
Thank you for your attention. I think this rim and tire size seems standard for the Quik. This is already in the pocket. Apart from that, I want to buy it from the rim called RC rim. I think it will suit this vehicle. But I can't decide whether it should be 15 "or 16". If it is 15 "what should the tire dimensions be? 16" If the tire dimensions should be, I am researching this. Also, most importantly, I try to find out which one is the most suitable due to the vehicle structure.
08.05.2020 17:12 # 7
Bugra
I use 195/45/16 tires. the appearance is beautiful but no comfort. you should be very careful in the pits. so that it does not make a rubber balloon or cut a rim. so you have to adjust the cheek thickness ii. my advice is 50-55 cheek. but it doesn't go to the 16 'rim. your vehicle looks like a tractor car. If the rim is 15, my advice is 195/50/15 or 195/55/15. If it is 16, it is 195/45/16 but as I mentioned it is risky and expensive. The more the tires get thinner, the higher the price. & nbsp; If you have friends who use different tire sizes in
16, you will also consider your comments. good luck.
08.05.2020 17:12 # 8
umut_25
Thank you very much, Master. My research supports what you say.
Since I do not know much about the subject, I scrutinize. I try to get the right product. It has become quite clear in my head as I reduced the options to 2
195/50/15
195/55/15 < / b>
It will be largely one of them.
08.05.2020 17:12 # 9
KenBlockJR
If you are going to get 15``, quiksilver original size is 195/55/15, don't think of another measure.
16`` 195/45/16, 205/45/16 or if you can find 195 / You can wear 50/16.
rc wheel is 17``. You should use 205/40/17 tires.
08.05.2020 17:12 # 10
umut_25
No, I will definitely not wear 17 ". I think it would be more accurate if I say the Rc model.
195/55/15 looks a little strange. >
I'm a little closer to 195/50/15, but let's take a look at 195/50/16 ... & nbsp;
08.05.2020 17:12 # 11
umut_25
Good morning guys. & nbsp;
A friend to my mind 205/55/15 I had to use a tire in dimensions. I have already mentioned the vehicle 206 Quiksilver. There is no sports spring on the vehicle. How do I stop and have problems if I use tires of this size?
08.05.2020 17:12 # 12
Bugra
[QUOTE = umut_25]
Good morning guys. & Nbsp;
A friend to my mind 205/55 / 15 it made me have to use tires. I have already mentioned the vehicle 206 Quiksilver. There is no sports spring on the vehicle. How do I stop if I use tires of this size and have problems?
`` how do I stop '' answer: there is no spring. The vehicle is high. 205 thick tires. 55 cheeks high. Here is an offroad car like a ride.
08.05.2020 17:12 # 13
umut_25
Now I know this vehicle's original tire rim dimensions are 195/55/15. I wanted to expand this a little bit. Sports bow reduces comfort, they said I did not want to wear it. Let me ask you when it's ready. There is a lot of difference between 5 cm sports bow and original bow. Guess how close the vehicle is to the ground?
I thought if I meant the problem, I would rub it because it is a wide tire.
