rim and tire
08.05.2020 17:54 # 1
seamad
Friends bought the car from the zonguldak and the car was a little raised from torsion because it was very hump, it was 4 fingers between the tire and the fender and it did not look nice. We get 3 fingers, we also have a steel rim and 195-60-15 tires, I wonder if there is a much damaged loss, I share your picture below, thanks
08.05.2020 17:54 # 2
seamad
By the way, I wrote the tire size incorrectly 185-60-15
08.05.2020 17:54 # 3
samet206
I guess it will be a problem for now, but torsion problems in our vehicles are legitimate.
08.05.2020 17:54 # 4
emre_akdag
I think the image is beautiful, good bye :)
08.05.2020 17:54 # 5
seamad
When the friends got into the car, another person got the sound of rubbing from the right, I went to the tire and they removed the tire rubbing from the inside side, we put the old tire again what do you think I should do
08.05.2020 17:54 # 6
samet206
[QUOTE = seamad] When one more person got into the car, there was a rubbing sound from the back right, I went to the tire and removed the tire from the inner side of the tire, we put the old tire again what do you think I should do [/ QUOTE]
I was surprised to rub that tire size, how many people do rubbing when I know that I wondered in total? . Either you will remove it from the back of the vehicle, or if you wear it before, you will detect the tire sizes that do not rub under these conditions and change the tire sizes, and find the solution looks very good.
08.05.2020 17:54 # 7
seamad
The tire does not rub from the top, it rubs from the inner cheek, if it increases the torsion, the inner cheek will rub again, I had to crush the inside of the mudguard. I do not want to do it.
08.05.2020 17:54 # 8
seamad
We tried 185 * 50 * 15 again, so it's rubbing old wheels for now.
08.05.2020 17:54 # 9
omer_tarsus
The old tires are original 175 / 65R14, 1.2 cm high and 1 cm wide as the current tire radius should not actually rub. If we consider it as a tour difference alone, there is a 7 cm difference in a tour.
