right signal
08.02.2022 13:32 # 1
erengul
Hi guys, I searched the
Forum but couldn't find it or I missed it. If there is a topic, do not worry.
I have a 2003 model 307 and although not always, when I turn on the right signal, the 'exit' sound that comes out while the normal signal is on, lights up faster than normal and both the front and rear signals do not light one day. I'm going to get in trouble because of this right signal :)
I took it to the electrician but it was working there damn thing I tried for half an hour it worked but I got out 10 minutes later it started giving the same error :)). Has anything like this ever happened to you before? Or does anyone know the solution to the problem? We could not find a solution because the electrician said there is a slight gap in the signal arm, but he cannot do it, the problem is probably something else, but I need to see it. I went to 3 electricians, 2 of them said I need to see and the other said I can't do this. I don't use it for a long time unless it's very urgent because of this problem. But sometimes I really need to use it and I'm constantly burning the 4s :).
If there is a master in Izmir that you want to go to this electrician, I can go there by the way.
08.02.2022 16:08 # 2
talip206
If there is a fast flashing sound, one of the bulbs is not lit. In general, if the bulb holders took water and made oxide, this happens a lot.
08.02.2022 16:23 # 3
erengul
Both are not lit, is it still from the bulbs? both work but
11.02.2022 09:54 # 4
It may be what our friend said, sir. Check all the signal bulbs. There may be oxidation in the sockets or the opening of the metal in the sockets over time. The last possibility may be a problem with the signal arm.
12.02.2022 01:28 # 5
Sakaryaspor
Hello,
In my car, the front right signal was having the same problem, I was fined by the police even after the inspection 🚔
One of the metal bearings in the headlight is stuck in the socket, so it does not light up because the nails in the socket do not come into contact with the signal. I solved the problem by opening the nails in the socket with a sharp object outward.
The same problem occurs from time to time. Open and open the nails, the nails are broken, I bought a new one, and I put it on by opening the nails.
22.02.2022 21:31 # 6
egeca77
I had the same problem. There was a screw on the underside of the inside of the right headlight, it was causing problems because the glass water pipe was loosening there, the electrician tightened it and fixed it.
24.02.2022 11:07 # 7
erengul
Friends, I solved the problem, the metal part of the front right signal sense was melted inside, it was burning sometimes, it was not burning. I solved it like this, I drilled a hole under the socket, I soldered the wires to the bulb, I got electricity from one of the headlights, the problem was solved. I also changed the rear signal just to be sure. I cleaned the sockets.
