right rear signal problem
08.05.2020 17:04 # 1
oguzhan53
friends 307 my car started to get bored because of the right back signal problem. Let me explain the incident, when I signal it, the signal flashes fast for 4.5 seconds, then returns to normal. When I burn the quads, the left signal is bright and the right is low. this problem puts me in a difficult situation in traffic. why he might be doing it. thanks for your help in advance ...
08.05.2020 17:04 # 2
fatihgg
Are you not using LEDs in the side fender signs, do you have an & nbsp; lamp that works with a led bulb?
08.05.2020 17:04 # 3
berk2309
can be oxidized in the sockets & nbsp;
08.05.2020 17:04 # 4
oguzhan53
When my license plate lights led, this problem occurred, I installed the standard bulbs. The problem has not improved. The oxide thing was called me, I cleaned it with contact spray and made fine sandpaper. It was not solved again.
