Right rear signal and stop are lit poorly
08.05.2020 20:20 # 1
radman206
Right rear signal and stop are weak. The signal sounds fast while signaling to the right. I checked the socket from the trunk is solid. Why could it be? radman206 2017-05-03 01:41:47
08.05.2020 20:20 # 2
The lamp socket sockets were oxidized, not from the sockets. disassemble and check.
08.05.2020 20:20 # 3
radman206
I'm going to try it today. thank you
08.05.2020 20:20 # 4
radman206
The stop was a little rusty and I cleaned it. Others were clean, though I cleaned it, the main problem continues.
08.05.2020 20:20 # 5
Is there evaporation water droplets in the stop lamp of my teacher after washing the car in rainy weather? Also clean the socket with wd40 or contact spray and replace the bulb, the same problem persists. Does it burn out when you apply the brake?
08.05.2020 20:20 # 6
radman206
Yes, master, I did as you said while cleaning. Now I also tightened the socket inlets, and it improved.
Thanks everyone.
08.05.2020 20:20 # 7
I am glad that the problem is solved, I say clean the other sockets without your hand :)
