Right Front voice
08.05.2020 21:02 # 1
x571
There is no sound on the straight road, passing through the cascade or passing through a pit on the road, but if the road is generally broken, if you go through the grounded road, which we call the stabilized road, there is a full sound like glaze glaze from the right front. Does it have a visual or manual examination?
08.05.2020 21:02 # 2
GokhaN
usually compile from shock absorber and damper wedge
08.05.2020 21:02 # 3
x571
[QUOTE = GökhaN] usually compile from damper and shock absorber block [/ QUOTE]
Is there a visual or manual examination that I can do to understand?
08.05.2020 21:02 # 4
x571
the subject is up to date. Looking for friends with detailed information.
08.05.2020 21:02 # 5
maximusti
I had the same problem, when I entered the rough roads, sometimes it made a sound when I entered the pits.
Ask the rod rods and swings.
08.05.2020 21:02 # 6
x571
[QUOTE = maximusti] I had the same problem, it made noise when I entered the pits sometimes when it was in the bad roads.
original of tie rod head 78 equivalent Turkish goods 17 tl. Have you ever tried which one is better price difference is too high.
08.05.2020 21:02 # 7
If you can find the rot head, get rıw - trw - delphi, hodja. Ayd is not troubled but its life is very short. trw and delphi around 40 tl
08.05.2020 21:02 # 8
x571
[QUOTE = sonerkyl] If you can find rot head, get rıw - trw - delphi, hodja. Ayd is not troubled but its life is very short. trw and delphi around 40 tl
Soner teacher, do you have any idea what the source of our nuisance is, and I want to examine it and go accordingly. I don't trust much. What can I do
08.05.2020 21:02 # 9
Teacher, turn the steering wheel fully and even lift it with a little jack. already z-rots you see rot heads, with a metal lever like a crowbar, I was a bit offended, there is a lot of space. Generally, the bellows of most of them is ruptured and loses its grease feature. then, when the socket is broken, this type of noise occurs.
08.05.2020 21:02 # 10
x571
[QUOTE = sonerkyl] My teacher turn the steering wheel fully and even lift it with a little jack. already z-rots you see rot heads, with a metal lever like a crowbar, I was a bit offended, there is a lot of space. Generally, the bellows of most of them is ruptured and loses its grease feature. then this type of noise happens when the slot is broken. [/ QUOTE]
I couldn't get it but when I hold the tire from the front and back and make it right and left, there is a gap in the wheel, it shakes. If we delay this repair a little like 6 months, will it hurt much?
And the shock absorbers are like this, but I could not understand whether they burst or oil leakage or mud. What do you think might be like muddy oil?
x571 2018-10-13 17:15:02
08.05.2020 21:02 # 11
Emirseng
I had the same problem. There was no ball change in the shock absorber. Then we saw that the shock absorber exploded. We changed it, there is no problem. While the vehicle is on the lift, they swing the tire slightly to the right. If the helix is ticking, it is depreciation.
08.05.2020 21:02 # 12
Just like the shock absorbers are gone, brother. As our counsel said, we need a good control.
08.05.2020 21:02 # 13
maximusti
[QUOTE = x571]
I couldn't reply because my teacher was out of town.
I had a delphi because I did not trust Turkish goods, I am not sure how much I paid for the fee, I had it done with many things.
08.05.2020 21:02 # 14
x571
[QUOTE = sonerkyl] just like the shock absorbers are gone, bro. As our counsel said, we need a good control. [/ QUOTE]
Did you use maysan mando? how is it? monroe from 250 to 280.maysan 110 tl. Is it worth the price difference? When changing the shock absorber, where should I change it?
x571 2018-10-15 20:11:09
08.05.2020 21:02 # 15
07ACG35
THE SAME SOUND WAS HAPPENED TO THE MASTER HOW DID I HAVE BEEN IN THE CAR. THEN I DOWNLOADED, I realized that when the sound changes to the pad, there is no new pad sheet.
08.05.2020 21:02 # 16
x571
[QUOTE = 07ACG35] THE SAME SOUND WAS HAPPENED TO THE MASTER HOW DID I HAVE BEEN IN THE CAR. THEN I DOWNLOADED, I realized that when the sound changes to the pad, there is no new pad sheet. [/ QUOTE]
does our craftsmen. There is a gap in my right wheel, apparently grasping by the side. front shock absorbers are also knurling. a mixture of oil and mud is plastered. Let me change them first.
08.05.2020 21:02 # 17
x571
my problem has improved.
the right tie rod head is out of order. I replaced it with the right and left originals. also front shock absorbers were out, I replaced front, rear, shock absorber. shock absorber mount and bearing. the problem has been fixed.
x571 2019-02-10 13:11:27
08.05.2020 21:02 # 18
crazysado
What did you get the shock absorber brand?
08.05.2020 21:02 # 19
x571
[QUOTE = crazysado] What did you get the shock absorber brand? [/ QUOTE]
Maysan
08.05.2020 21:02 # 20
I'm glad your problem is resolved, hodja.
