right door open warning is not working
08.05.2020 20:40 # 1
husem
Hello, when my left front and rear right rear are left open, there is a warning on the screen, but if the right front door remains open, there is no warning.
Where is the sensor / eye that controls this, how can it be, what should I check?
I huseyın 2017-12-11 11:37:20
08.05.2020 20:40 # 2
Sir, in the 206 door locks.
08.05.2020 20:40 # 3
husem
Looks like the lock-up is not possible to check.
08.05.2020 20:40 # 4
pusutr
If they shut and open normally with the controller, they cut the cable to the door open warning sensor.
08.05.2020 20:40 # 5
husem
I would like to check if I knew what it was like.
08.05.2020 20:40 # 6
serdar5353
Although my right door is closed, it gives warning. how can i cancel sensor
08.05.2020 20:40 # 7
husem
[QUOTE = serdar5353] it gives warning when my right door is closed, it does not close with the remote control. how do I cancel sensor [/ QUOTE]
I was doing my left door, I changed the door lock.
08.05.2020 20:40 # 8
pusutr
I canceled it by giving 20 TL to a keymaker in the industry. It is currently at most 40 TL. I have a cab cut it off and cancel it.
08.05.2020 20:40 # 9
husem
[QUOTE = pusutr] [QUOTE = serdar5353] gives a warning even when my right door is closed, it does not close with the remote control. how do I cancel sensor [/ QUOTE]
I added the cut cable to my business list over the weekend.
I am explaining my business list for you to wonder Tongue
1. Trying to remove and dry the left front floor carpet
2. road computer screen will change
3.right left stop will change
4.cruise control operation will continue
5. The piece I broke in the right front cable gaiter will be pasted
6. Right front door will look for cut cable
it's been a lot of work ...
08.05.2020 20:40 # 10
serdar5353
I wonder which cable is cut to cancel the sensor
08.05.2020 20:40 # 11
serdar5353
they don't stop here
08.05.2020 20:40 # 12
luridline
Hello, have you been able to fix the problem?
08.05.2020 20:40 # 13
husem
I found the cable cut, but I was not interested to avoid expense :)
08.05.2020 20:40 # 14
luridline
I also had an alarm, got it ticked before me, took care of it over the weekend. There is an orange wire from the left door to the central lock. Don't cut it off. I connected the cable. Problem solved. Keep in mind, if you are using an automatic lock (automatic locking when the vehicle moves), only the information on the central lock has been opened when the right door is opened and there are problems with locking. Since yours is the right door, there is no problem, but since mine is the door of the driver, I had to solve it in case I forget to lock it with thoughtfulness. If you can find the other end, I suggest you solve it yourself.
