Ridiculous malfunction caused by quick entry into the pit
08.05.2020 16:50 # 1
dmnbl
Hello,
& nbsp; After going into the pit with 60-70 with the vehicle, the airbag light started flashing and the indicator lights are gone, why do you think it might have been? dmnbl 2012-06-05 04:04:23
08.05.2020 16:50 # 2
toga406
I think a short circuit or a fuse or cable breakdown that causes an electrical breakdown
08.05.2020 16:50 # 3
mehmet6667
I think it protected the vehicle body under the hood, there is a button in the left amater, hold it down, hold it for about 5 seconds, then look at it again.
08.05.2020 16:50 # 4
[QUOTE = mehmet6667] I think it protects the vehicle body under the hood, there is a button between the left shock absorber, hold it down for 5 seconds, then look at it again. prevents the pump from stalling and potentially greater dangers. If the problem is actually at this button and no action is taken, the vehicle should not be operating at the moment. More detailed information is required.
08.05.2020 16:50 # 5
ttaylanaa
If more information is given, I am sure that the friends here can write logical comments about what might happen. When the indicator lights go out, are the indicators not working? What warning does the vehicle give? Do you sometimes do this and sometimes cut it? If you got the car connected to the computer, what are the malfunctions?
& nbsp;
Like an electrical fault. It may be incidental that it occurs after entering the impulse. If all malfunction lights are on and the indicators do not work, the problem may also be caused by the coil. get.
ttaylanaa 2012-06-05 13:52:28
08.05.2020 16:50 # 6
dmnbl
[QUOTE = ttaylanaa]
If more information is given, I'm sure friends here can write logical comments about what might happen. When the indicator lights go out, are the indicators not working? What warning does the vehicle give? Do you sometimes do this and sometimes cut it? If you got the car connected to the computer, what are the malfunctions?
& nbsp;
It's like an electrical fault. It may be incidental that it occurs after entering the impulse. If all malfunction lamps are on and not working on the indicators, the problem may also be caused by the coil. .
Indicators are working but the lights under it are not lit. The only warning on the car is the flashing of the airbag light. It did not go out after entering the pit. I did not connect the car to the computer yet. I think it is electrical, I don't understand much. Could the indicator problem have something to do with insurance?
I would also like to thank you for the comments
08.05.2020 16:50 # 7
technodex
And I think the battery will go off the pole, wait a bit and try it.
08.05.2020 16:50 # 8
okan4037
had a sensor on the ceiling of the ccs & nbsp; When he suddenly got into the pit, that sensor cuts the fuel in danger, and what was the task of opening the airbags fast? I do not think it will be such a coincidence, it's not electrical.
08.05.2020 16:50 # 9
soneroo
first of all, if the indicators are working and the lights are not lit, the lights may have cut off.
08.05.2020 16:50 # 10
ttaylanaa
[QUOTE = dmnbl] [QUOTE = ttaylanaa]
& nbsp;
& nbsp;
You should give some more detailed information. Let me be. Could the indicator problem have something to do with the fuses? But judging by what they say has nothing to do with him & nbsp;. As the friends said, there was something under the seat.
get over again
