Revolution Rise
08.05.2020 18:49 # 1
tolga.onal
I went to Konya during the holiday, I traveled 1768 km to the country, made a total of 360 TL to 1768 km. As for my problem; I'm going with 120-130. When I need to accelerate suddenly in 5th gear, the pressure to the end of the gas is going to be 6 to 6 and a half when it is at 4 thousand. The car starts to shout. I bought a 17 inch rim for a week. I got a tire on 225/45/17 I wonder if it is related to them.
08.05.2020 18:49 # 2
tolga.onal
Doesn't have an idea :)
08.05.2020 18:49 # 3
captain_b5
You said there was no problem with the clutch, but it turns out that the clutch is missing.
08.05.2020 18:49 # 4
Barut
Printing is probably missing the pad.
08.05.2020 18:49 # 5
muro_60
So how many miles does it show when it is 6000?
08.05.2020 18:49 # 6
tolga.onal
The pointer rises slowly upwards at 120 and returns to its normal speed when the last gas pressure reaches 140-150 after 4-5 seconds. I know it is from the linings, but for 2 years, the clutch's clutch does not grip above or below or there is nothing shaking or shaking in normal use.
08.05.2020 18:49 # 7
muro_60
[QUOTE = tolga.onal] pointer is rising slowly, while it is 120 upwards, it returns to its normal speed when it is 140-150 after 4-5 seconds after the last gas pressure. I know it is from the pads, but for 2 years, the clutch clutch does not grip above or below, or there is nothing shaking in the tremor, in normal use. I wonder if the rim is going to be wasted. Is the rim back to waste, and it ends, buddy :))
08.05.2020 18:49 # 8
okan77
[QUOTE = muro_60] [QUOTE = tolga.onal] pointer slowly rises up to 120 while returning to its normal speed when the last gas pressure is 140-150 after 4-5 seconds. I know it is from the pads, but for 2 years, the clutch clutch does not grip above or below, or there is nothing shaking in the tremor, in normal use. I wonder if the rim is going to be wasted. Is the rim going to waste, and it ends, buddy:)) [/ QUOTE]
If the speed and speed do not increase at the same rate :) I agree with the friend :) The rim in the tire is not wasted, so ..
08.05.2020 18:49 # 9
tolga.onal
it was just an idea :) because I had a taxi a few years ago when the man pressed the brakes did not hold the tire rim, I said I wonder if he said he did not hold the tire rim when I asked him. I don't have any problem when I don't press the gas until the end, I don't have any problem in normal use.
