Revolution drop after 3000 cycles
08.05.2020 19:59 # 1
leqendtime
hello friends, 2005 hdi 1.4 206 user, I do not force the vehicle at full speed, it will be rare, when the lights are empty when it is empty, I squeeze it, the problem I will talk about is in the 3rd gear, I get up in the 1st gear, I raise it in the 3rd gear, the same in the 2nd gear, the same time in the 3rd gear, while the acceleration is around 3.3 RPM the tachometer suddenly drops up to 2.2 rpm and then starts to rise again, it is not possible to cut my foot from the gas while the rpm is falling, does anyone know what these friends are?
08.05.2020 19:59 # 2
teacher, you have checked the turbo hoses, there may be situations such as looseness leakage. or there may be a problem with the throttle.
08.05.2020 19:59 # 3
leqendtime
okay teacher I'll have a look tomorrow thanks
08.05.2020 19:59 # 4
samet206
The problem may be on the press pad.If the clutch is missing, there is a possibility that such a situation will happen.
