reversing lights
08.05.2020 16:25 # 1
mon
Good evening everyone. My reversing lamps have not been on since I bought my vehicle. I checked the lamps, both of them are intact. I checked the fuses, no problem. & nbsp; my guess is there is a problem with the reverse gear sensor. Where is the reverse gear switch? Waiting for help from friends who know it, easy to come.
08.05.2020 16:25 # 2
kaan__
under the battery on the transmission with gray socket & nbsp; "Wink"
08.05.2020 16:25 # 3
Plug the cable of the sensor mentioned by kaan first. Since it is a sensor that operates in simple logic, its function is to short circuit the incoming cables. You can short-circuit the cable you disconnected with an additional cable. This way you can tell if the lamps are on and if the sensor is defective. Good luck with.
08.05.2020 16:25 # 4
mon
thank you guys
is this?
08.05.2020 16:25 # 5
djchaos
If you are absolutely sure, disassemble and try it. If you are not sure, show it to an electrician.
