Resolved audio from 4000 rpm.
08.05.2020 17:54 # 1
tilbe307
Hello friends, first of all, Happy August 30th Victory Day.
When it comes to my problem, my car comes out with a sound similar to the belly noise, especially with the humming of the engine, in 4 cycles. what do you think could be the reason?
tilbe307 2013-09-01 17:05:51
08.05.2020 17:54 # 2
qqyyxx
may be a problem in the heating system
08.05.2020 17:54 # 3
tilbe307
No teacher said they might be from balls but I don't understand
08.05.2020 17:54 # 4
error
It is likely to be a muffled exhaust sound.
08.05.2020 17:54 # 5
tilbe307
problem solved. The reason why the axle is making 3000 to 4000 revolutions with the ball disassembled is because of the load on the ball because you are loaded on the engine and it turned out that it makes sound. We settled for 50 TL. bearing 20 labor 30 tl. have a nice day
08.05.2020 17:54 # 6
elestern
If this sound looks like a bubbling or balanced kite sound, it seemed to me the way it seemed to me.
08.05.2020 17:54 # 7
kuscu38
LOOK AT THE ABI SHIFT WHEN IT COMES BACKWARD, LATER OR AKIS DISTRIBUTED ...
08.05.2020 17:54 # 8
tilbe307
Yes, the sound you specified was not very clear when the gear was idle.
08.05.2020 17:54 # 9
Alicilik
There was a similar problem in Auris, after I climbed into a small stone, after 90-120 it was as if a second engine started to work in the vehicle. After 120 I cut up to 200 grams did not tremble. Service inspected axles will change. Changed from warranty. Mine is not connected, regardless of road or cycle, 90d started and cut at 120.
very inexpensive parts + labor 650tl kept on my bill
