Resistance Switch
08.05.2020 19:38 # 1
Oguzhn
good day guys In my 2004 1.4 HDI vehicle, the resistance button does not work. Is it possible to change this key alone or the air conditioner internal temperature and resistance button need to change this triple combination. and how do I remove that part. I dismantled the front console completely, I also removed the place where the air conditioning keys were, but I could not get out, so I did not have the chance to interfere with the keys, I did not want to break it more than the first day :) I am waiting for your information sharing, have a nice day :)
08.05.2020 19:38 # 2
Actually, it is not very difficult. As far as you can tell, there are a few issues related to the removal of the control panel in the forum, you will find that if you investigate a little, you will find that the control panel has two nails on the top and bottom, the black part is already in your hands and the circuit rest is in your hands :)
08.05.2020 19:38 # 3
Oguzhn
[QUOTE = sonerkyl] is actually not very difficult, as far as you can tell, there are a few issues related to the removal of the control panel in the forum. in your hands:) [/ QUOTE]
Master, I pulled out his nails, too, but I had to push it up a bit to get it out of the console and take it out of there.
08.05.2020 19:38 # 4
I recommend you disassemble it if you say I can plug it in. I don't remember how many times I disassembled it :) so you can work more comfortably. If you were ankara, I had a card with a burned circuit. Of course, we would look at the convenience of the photo, it would be more comfortable.
my http://forum.peugeotturkey.com/forum_posts.asp?tıd=40709&title=klima-kontrol-paneli-dugme-degisi
buddy 307 is another friend of ours.
you http://forum.peugeotturkey.com/forum_posts.asp?tıd=27784&pn=1&title=klima-dugmeleri-nasil-sokulurlanet-ol
sonerkyl 2016-02-05 15:33:43
08.05.2020 19:38 # 5
Oguzhn
[QUOTE = sonerkyl] If you say I can wear it, I recommend you to disassemble it. If you were ankara, I had a card with a burned circuit. Of course, we would look at the convenience of the photo, it would be more comfortable.
I looked at your subject, but the buttons do not fit, I will try to disassemble it at the first available time and I am thinking of wearing the skin that you put on the keys, and I will try to remove it all together. Thank's for the information..
