Resistance adjustment construction
08.05.2020 14:01 # 1
Emin
During the winter, drivers often encounter vision problems due to the mist formed on the rear window. The only way to remove the mist is to run the resistance. However, the thin resistance wires that break for various reasons cause the drivers' head to hurt. However, these wires can be repaired in a few minutes with silver glazed paints sold in the market.
Makes steam
Even if you will forget about its existence in the summer months, you can repair it when the rear window resistance fails. Resistance wires, which have a very thin and sensitive structure, either break while the glass of the car is wiped or the car stationwagon is broken during loading. These thin and sensitive resistance wires, which are connected parallel to each other, which warms up the misting in the rear window, show themselves by making misting when they break. Robust ones continue their duties.
5 minutes to repair
Most users are worried about having the broken resistance wire repaired. Going to the service for a simple wire seems like a laborious task. However, as the wires continue to break, the rear window will completely mist, and then the real problems begin. It would be wrong to wait for all wires to break to go to the workshop. With silver glaze conductive paints, you can repair your car's resistance in 5 minutes. Moreover, alone.
How to repair the resistance?
For repair, it is first necessary to determine which wire is broken. To understand this, the resistance is run. As the mist on the working wires is dissolved, the mist will remain in the area where the broken wires are located. The broken on the wire can easily be found in the area where the wheat is left.
It is necessary to clean the surface before applying the silver glazed conductive paint on the broken wire. For this, you should wipe the surface with a damp cloth and without pressing too hard to avoid damaging other wires.
After the cleaned floor has dried, a special cardboard with a space as thick as the resistance wire is placed on the floor in order to prevent the silver glazed conductive paint from sticking out. Then, silver glazed conductive paint is applied to that space, and the ends of two broken wires are connected. If there is no special perforated cardboard coming out of the box, both sides of the broken part can be taped to prevent the paint from overflowing.
The most important point to note here is that silver glazed paints must be shaken well before use. After applying the paint, it is enough to wait 5-6 hours to dry. During this time, the resistance should not be operated. However, if you don't want to wait that long, you can keep a hair dryer on the dye and let it dry faster.
Attention
Silver glazed paint can only remove the breaks in the rear window resistance. To be used in damages in the main connection points of the resistance and in the resistance failures in the heated windows in the rear view mirrors of the windshield and side rearview mirrors.
08.05.2020 14:01 # 2
For the information, please make sure :)
08.05.2020 14:01 # 3
hasimayaz
08.05.2020 14:01 # 4
HakanGokdemir
Thanks for sharing ...
08.05.2020 14:01 # 5
A.L.P
thanks for sharing
