replacing the glow plug
08.05.2020 17:28 # 1
Mustafa-almanya
Hello Friends,
& nbsp; I bought the spark plugs for & nbsp; 407 SW 2.0 HDI 135. It is very difficult to change my master in Germany. I was forced to change me in the summer in Turkey. Can you suggest a good master to replace the spark plugs in Ankara (I would appreciate if it comes with the address).
I am waiting for the suggestions of experienced Arkads.
08.05.2020 17:28 # 2
[QUOTE = Mustafa-germany] Hello Friends,
& nbsp; I bought the spark plugs for & nbsp; 407 SW 2.0 HDI 135. It is very difficult to change my master in Germany. I was forced to change me in the summer in Turkey. Can you suggest a good master to replace the spark plugs in Ankara (I would appreciate if it comes with the address). it is not a very skillful job, as long as you have the necessary key set. I just changed the spark plugs of 206 myself 2 hours ago. But 407 is different. I won't know exactly.
08.05.2020 17:28 # 3
[QUOTE = hLL 206]
Actually, it is not a very skillful task, as long as you have the necessary key set. I just changed the spark plugs of 206 myself 2 hours ago. But 407 is different. I will not know exactly.
Do not mix the spark plug with the spark plug. Replacing the glow plug is more risky than difficulty. The risk of breaking is high.
08.05.2020 17:28 # 4
[QUOTE = koliva] [QUOTE = hLL 206]
Actually, it is not a very skillful job, as long as you have the necessary key set. I just changed the spark plugs of 206 myself 2 hours ago. But 407 is different. I will not know exactly.
Sorry I got it wrong. 18:45:11
08.05.2020 17:28 # 5
qqyyxx
glow plugs are different 1.6 h. High probability of breaking when removing due to boiling. I don't know the 2.0, but I think it applies to the whole. I don't think it will guarantee that any & nbsp; master can remove it without harm. & nbsp; Where did you know they were faulty, what kind of symptom showed?
08.05.2020 17:28 # 6
elsoberano
If you can go to the self-icon peugeota, I think they can handle it. elsoberano 2013-03-30 18:53:51
08.05.2020 17:28 # 7
Mustafa-almanya
First of all, thank you for your answers.
My friend is right, the spark plugs and spark plugs are very different. I was replacing the spark plugs of my gasoline car myself.
Because the spark plugs change every 100000 km, they are completely in place. Its position in the engine is in a very wrong position. Unlike 1.6 HDI, since the engine is larger, the working area is much less. I have tried many times, at different times. The same error is coming continuously.
Thanks from Germany
08.05.2020 17:28 # 8
[QUOTE = Mustafa-germany] First of all thank you for your answers.
Because the spark plugs change every 100000 km, they are completely in place. Its position in the engine is in a very wrong position. Unlike 1.6 HDI, since the engine is larger, the working area is much less. I have tried many times, and at different times. The same error is coming continuously. error round P1351. Your guess is correct. The problem will disappear when you replace the spark plugs. After replacing the spark plugs, remember to delete the error from the computer.
08.05.2020 17:28 # 9
cerci07
The engines that are taken from an old position are different, but the technique is generally the same and dangerous. In the first run of the 1.4 fiestan, the frequent patching of the spark plug warning started to disturb me. I wanted to share with you how I got it. the path followed for insertion1 insert the pole of the battery 2 insert the air filter box 5 screw holding the places indicated by the red arrow pointed in the arrows indicated by the arrows, have the spark plugs3 insert the air pipe of the egr valve, the part of the cables that are caught in the back part of the cables that are not attached to the blue part of the cables that are not attached to the cable, Take out the screw and clamp of the egr valve pipe after removing the knob6 firstly, we insert the screws holding the spark plug's wires. We can connect it to the battery to see if it is working, if it is flushing, it is solid or we can control it with the device as in the picture. We set the device to ohm setting. The solid spark plug should be between 0.6 ohm and 1 ohm. mine gave 1.1 - 1.2 spark plugs with 700-800 offset numbers will be the last spark plug that you will have more difficulty in different methods to find out if the spark plugs are broken and have a mirror with you
08.05.2020 17:28 # 10
Mustafa-almanya
Illustrated explanation is very good.
Thank you very much
08.05.2020 17:28 # 11
Mustafa-almanya
Hello Friends,
& nbsp; I could not get the exhaust inspection because of the glow plugs error (P1351). & Nbsp;
& nbsp; To the attention of friends who have a similar problem.
08.05.2020 17:28 # 12
cerci07
If you were here, we were away from the examination, but you are away & nbsp; "Big
cerci07 2013-04-24 20:32:21
08.05.2020 17:28 # 13
tellotello
I have made transactions in two places in Ankara, one is at "Vatan Peugeot" Atisan junction, the other is "Öz Simge Peugeot" and there is no problem in the transactions. My spark plugs also changed in Vatan Peugeot in 100 thousand, no problem for now (my engine is 1.4 hdi). I don't think there's anything they can't handle. If necessary, you take their phones, ask for their places, stop by, but they are both in easy places anyway. & Nbsp;
08.05.2020 17:28 # 14
Mustafa-almanya
They did not give my car's Exhaust Inspection due to the glow plug. Therefore, I have no chance to get it done in Ankara. I have to get it done in Germany.
Thanks to everyone
& nbsp;
