REPLACEMENT OF THE REEL PLATE LIGHTING TO 206 FELINES
08.05.2020 17:28 # 1
impertore
HELLO FRIENDS ;
One of the 206 feline backplate lights does not light up. I wanted to change it, but I could not open the lamp glass. I do not want to go to the service for bulb replacement. If anyone knows how to open, please get help. Is tşk ...
08.05.2020 17:28 # 2
plawert
There are two types of either a hole in that transparent part of the license plate lamp, something like a thin screwdriver and a bit of a screwdriver, but it is likely to be broken, because the hard plastic piece or the tailgate that removes the interior trim is pressed in the forum, by removing it from its nails and changing the bulb.
08.05.2020 17:28 # 3
impertore
THANK YOU VERY MUCH ALLAH GET ...
08.05.2020 17:28 # 4
[TUBE] bpclqg0irjc [/ TUBE]
08.05.2020 17:28 # 5
plawert
What do you mean, buddy, we will get a lot of money on the services :)
08.05.2020 17:28 # 6
aknard
we will definitely break this move :)
08.05.2020 17:28 # 7
MuRaTTTT
I broke, watch your nails, I am impatient while removing it, I pulled a little hard.
08.05.2020 17:28 # 8
Alicilik
The strongest is to remove the luggage plastic and save your feet from there. I once broke the long leg of all that plastic. I was never tried again. I remove the back plastic and take it off easily. I even clean it up and wear it.
08.05.2020 17:28 # 9
rockwaryumm
[QUOTE = Buyer] The most robust is to remove the luggage plastic and save your feet from there. I once broke the long leg of all that plastic. I was never tried again. I remove the back plastic and take it off easily. I even clean it up and wear it.
I think it is easy to change it from the back plastic. I always change every car from the inside. When you look at it, it becomes clear how to disassemble it.
