Replacement of 307 heater radiators
08.05.2020 16:27 # 1
fatihkiziroglu
Hello. I searched the subject in the forum, but I could not find detailed information. My 2003 peugeot 307 xt vehicle's mat was constantly getting wet in the driver's room and the engine was decreasing water. They said that the screw was worn out in time and the antifreeze decreased. They replaced the missing screws again, they decreased again, they went again. I did not look hot..because if the chest is removed and inserted, I think there will be clicks that do not happen again and there will not be parts that will not work. / P>
08.05.2020 16:27 # 2
Hello,
You must introduce yourself first, as per the forum rules. Please contact the following topic:
http://forum.peugeotturkey.com/forum_posts.asp?TID=7516&title=new-years-cautious-contact-before- < br>
I shared how to replace the gasket last day in the section on how to. The vehicle is exactly the same as yours. There may be the same problem in yours. Also, there is no need to insert a torpedo to change the heater core. Do not be next to the master who says you need it.
http://forum.peugeotturkey.com/forum_posts.asp?TID=20250&title=soutma-waterinin-aracn-%DDine-szmas-problemi < br> koliva 2011-12-18 23:08:37
08.05.2020 16:27 # 3
ose
My Koliva teacher was helped :)) I was late.
08.05.2020 16:27 # 4
[QUOTE = ose] My Koliva teacher helped :)) I was late. [/ QUOTE]
This time it was like this "Wink
08.05.2020 16:27 # 5
yavuz25
[QUOTE = fatihkiziroglu]
Hello. I searched the subject in the forum, but I couldn't find detailed information. My 2003 peugeot 307 xt vehicle's mop in the driver's room was constantly getting wet and the engine was decreasing water. They said that they wore 1 screw, and the antifreeze disappeared over time, they replaced the missing screws again. They replaced the missing screws again. I did not look at it very warmly. Because I think if there is a chest, it will be uncluttered clicks and parts that will not work. I expect help from friends who have this problem. Is there any other way?
It is a very troublesome job to disassemble and put on the breast. If it is coming from a small place, there are radiator hole closers. alt = "Wink" title = "Wink" />
08.05.2020 16:27 # 6
emin15
The torpedo does not need to descend to replace the 307 heater radiator & nbsp;
08.05.2020 16:27 # 7
yavuz25
[QUOTE = emin15] 307 does not need to descend the torpedo to change the radiator & nbsp; [/ QUOTE]
if pedals are not fixed.
08.05.2020 16:27 # 8
fatihkiziroglu
Koliva thank you very much. Your sharing has worked very well. First I went to the authorized service, I told the situation and what you did. " they edecem.teşekk .....
