replace the crank sensor
08.05.2020 21:06 # 1
umut1001
My slm.2008 model 206 automatic car is starting from time to time but it was not working. It was working when I tried the next day.
The sensor has changed before. The replacing man has replaced the regular bolt instead of the normal bolt. There are so many offensive people in our country.
08.05.2020 21:06 # 2
GokhaN
Hi, the best thing is to connect this tool to a computer when you think exactly why it doesn't work, there are many alternatives.
08.05.2020 21:06 # 3
umut1001
Slm. I disconnected the gas pump. I connected it with a small battery. The pump of gas is very strong. I eliminated the gas pump failure. It could possibly be from the pump relay. I could not find the gas pump relay. Where is it? They say under the medicine, but I could not see it.
08.05.2020 21:06 # 4
umut1001
Unfortunately, the crank sensor does not show up on the computer in the peugeot 206, unfortunately.
08.05.2020 21:06 # 5
umut1001
Slm. I think the problem was caused by the immo antenna. When it rained, the water was getting from the top (from the radio antenna input) and the car was steaming. Someone has oxidized the forum because of the steam inside and the car does not work. I'll try to clean it tomorrow. then I will clean the oil with lining spray.
When the door was half-turned, there was no beep when I opened the door, which showed the immo problem. (unable to read the key)
08.05.2020 21:06 # 6
umut1001
Yes friends. I ran the car. Can't read the car key. After doing the door 5-6 times, I can read and work the immo.
08.05.2020 21:06 # 7
talip206
[QUOTE = umut1001] yes friends. I started the car. Can't read the car key. After I do the door open and close, I can read and work the immo.
Get past where is what you call the immo antenna. Is it where the normal radio antenna is.
When you reach the solution, we would appreciate if you add detailed information and photos.
08.05.2020 21:06 # 8
umut1001
Thanks Immo, something black in the shape of a ring at the entrance of the ignition key.
Something like this
I think he reads from that ring. Connector in that ring. I think it oxidizes there.
umut1001 2018-12-26 23:07:00
