Repair sign
08.05.2020 13:59 # 1
My friends using 106 question to you. When you turn on the ignition of your vehicle, a number appears first where the km counter is located, and there is a repair key sign next to it, and those numbers fall off periodically. For example, my 2200 days are now 100. and it fades. When you start the engine, the numbers about normal km are displayed. my problem is hours above normal mileage. a repair key sign appears next to that watch. how we solve this issue. If we connect it to the computer in the service and increase that number again, is there a simpler way
08.05.2020 13:59 # 2
o The sign shows when you need to go to the service, so how long after you go to the service, when the service is done, the service will be restored.
08.05.2020 13:59 # 3
I did the maintenance of oil, filters, brake centers etc. 2 days ago in the service, but I have to go to my service now :)) How can we remove that mark? Or do you mind if it stays constant
08.05.2020 13:59 # 4
hasimayaz
There is a procedure for resetting in the booklet. For example, in 206, you hold down the left button without opening the contact. Then, if you turn on the ignition and wait a few seconds, it starts counting down from 10, when the timer is over, it is set to 20000 again.
08.05.2020 13:59 # 5
sinan-s
That sign doesn't matter ... You can reset it from the booklet.
08.05.2020 13:59 # 6
There is a procedure for resetting the booklet [QUOTE = hasimayaz]. For example, in 206, you hold down the left button without opening the contact. Then, if you turn on the ignition and wait a few seconds, it starts counting down from 10, when the timer is over, it is reset to 20000 [/ QUOTE]
What do you call the left button, Hodja?
08.05.2020 13:59 # 7
I understand .. then I need to find a booklet about 106 thanks.
08.05.2020 13:59 # 8
I found it. you press and hold the right button on the display, after the ignition is turned on and counts up to 10, the process is completed after the = 0 sign appears on the screen.
08.05.2020 13:59 # 9
There is a procedure for resetting the [QUOTE = gs5165] [QUOTE = hasimayaz] booklet. Then, if you turn on the ignition and wait a few seconds, it starts counting down from 10, when the timer is over, it is reset to 20000 [/ QUOTE]
If I think that the bar there is the indicator of the indicator lights on the left of the daily km on the right, Haşim meant it.
08.05.2020 13:59 # 10
sinan-s
[QUOTE = DERAN_TUYNER] [QUOTE = gs5165] There is a procedure for resetting the booklet [QUOTE = hasimayaz] .. for example, you hold the left button in the 206s without opening the contact. Then, if you turn on the ignition and wait a few seconds, it starts counting down from 10, when the timer is over, it is reset to 20000 [/ QUOTE]
Yes it
08.05.2020 13:59 # 11
but the peugeot 106's right button says from me :) I'm a liar of the booklet :)
08.05.2020 13:59 # 12
iLLeGaL
Get well soon...
08.05.2020 13:59 # 13
hasimayaz
There is 2 buttons on the dashboard.
