Repair of Oil Vapor Pipe |
| 08.05.2020 20:10 | # 1 |
Price: 100 TL When I think about it, think how it will be, I found the bright and good quality of the electrical band. If the electrical band is not the same or not, some of them are unhealthy and cheap, and they release themselves from the heat and open in the cold weather. So the quality of the electrical tape is the bright one. I wrapped the folded area beautifully and stretched it and stretched the bandage, it is not clear when I do not look very carefully as shown in the pictures. Actually, what I thought of was to wrap it completely, because at the temperature of the engine, this piece is plastic and it dries up and breaks in the slightest stretching. Conclusion: I have been using it for 4 months, neither throwing, deterioration nor anything else has happened. |
| 08.05.2020 20:10 | # 2 |
Your health is nice and useful
| 08.05.2020 20:10 | # 3 |
Oktkor |
It is not clear when you look carefully. It also requires separate mastery to break it or do it. :)
| 08.05.2020 20:10 | # 4 |
[QUOTE = Oktkor] It is not clear when you look carefully. It also requires separate mastery to break it or do it. :) [/ QUOTE] It is very simple to break :) I did not feel that my soft stretch was breaking right away. I was looking at something when it came out :) Because this material is plastic, it hardens from the temperature of the engine over time and breaks when it hardens. |
