Removing glass from the controller at 307
08.05.2020 14:17 # 1
Faruk
In the 2007 307 premium, I turn the key to the right and wait, the doors are locked and the windows are lifted, but what I did from the remote control (I pressed, locked, pressed, etc.) the windows do not. is there a setting for this please can you help me ??
thanks in advance
08.05.2020 14:17 # 2
When camlaqr is open you need to get up when you hold down the lock button for 1 second .. either there is a problem or this feature is not available to the vehicle
08.05.2020 14:17 # 3
IsmailAtes
If the battery terminal is removed, this feature may be inactive. You can try to activate it if you want.
To activate, open the ignition, lower the front two windows until the end, then lift the front two windows, but do not release the keys for about 10 seconds. hold it up, then lower both windows again.
After this process, after locking the vehicle from the remote control, long press the lock button to see if it is active.
08.05.2020 14:17 # 4
Faruk
[QUOTE = IsmailAte] If the battery pole is removed, this feature may be inactive. You can try to activate it if you want.
Health will be my first job tomorrow.
08.05.2020 14:17 # 5
coyote26
I think the battery has nothing to do with the pole head.
08.05.2020 14:17 # 6
Faruk
I tried it yesterday, it was really super.
health thanks to your labor
