Removing 307 heater cores
08.05.2020 14:09 # 1
selcuk-307
I read the removal of the front panel for friends 307 from the forums. Can we easily disassemble the heater core after the front panel is removed, as in falcon-born? Since it is a mechanism that constantly warms and cools, tomorrow someday the pipes will crack, burst or leak the water. A friend had her chest ripped so strange noises began to come.
& nbsp;
So is it necessary to remove the chest completely?
& nbsp;
I am eagerly waiting for the comments of the master master on this matter.
08.05.2020 14:09 # 2
H-a-d-i
good subject. in a style that can happen to anyone. Come on, masters, get a hand!
08.05.2020 14:09 # 3
hasimayaz
It is impossible to replace the honeycomb without removing the entire chest. It is very laborious and needs to be done carefully. Unfortunately, I heard a lot of complaints that he did not hold stitches afterwards.
08.05.2020 14:09 # 4
my double-sided air conditioner had to be replaced on the right side faucet. he ate the gear. They said they should get honeycomb. of course the chest will be removed. I innuendo. We took it in the heat. we get cold in summer. now. & nbsp;
08.05.2020 14:09 # 5
arifkemal
i have 206. & nbsp; they said honeycomb is clogged in me. The masters in the industry said that the front console should be dismantled, I did not disassemble it. then they went to peugeot fatih authorized service, they said they blocked the honeycomb & nbsp ;, but instead of removing the console, they took it under the steering wheel for 5 minutes :) Of course, at 307, I don't know if the console shape allows it, but the console came out without dismantling it even though it had to be dismantled. When it is removed, the most important thing is & nbsp; Gaskets at the ends of the pipes leading to the honeycomb. Mine was worn back and put back on the road, and antifreeze dropped on my feet on the road and the gaskets changed afterwards.
08.05.2020 14:09 # 6
Aytac
307's Work Is A Great Understanding .. Easy Come ..!
08.05.2020 14:09 # 7
H-a-d-i
friends, we learned the original from the authorized service, the honeycomb was removed without removing the front chest.
08.05.2020 14:09 # 8
betermen
[QUOTE = Come on] friends, we learned the original from the authorized service, the honeycomb was removed without removing the front chest. [/ QUOTE]
hi what service is this? I showed it to the authorized service in dudullu. They said it must be removed. Reviews
08.05.2020 14:09 # 9
selcuk-307
[QUOTE = betermen] [QUOTE = Come on] friends, we learned the original from the authorized service, the honeycomb was removed without removing the front chest. [/ QUOTE]
< DIV>
& nbsp;
I was very surprised to see the subject I opened a year ago in front of me.
I wrote specially for you and also click:
& nbsp;
DIV> http://forum.peugeotturkey.com/forum_posts.asp ? TID = 12974 & amp; PID = 183674 # 183674
selcuk-307 2011-02-19 14:29:02
20.02.2022 11:54 # 10
Aliihsan
Hello, the floor mats in the driver's cabin of my 308 T7 Vti vehicle were constantly getting wet, I took it to the mechanic, he said that it came from the heater core, for the replacement, the chest had to be completely disassembled.
21.02.2022 10:26 # 11
It depends, sir, he does not know the master job.
https://www.youtube.com/watch?v=WsMpFVi6GgM
