Remote Control Problem
08.05.2020 13:56 # 1
Good work
I have a 2002 model gasoline Peugeo 307 car. This car has a brain malfunction last month. They changed their brains in the brain. All functions have improved but the remote control on one key has stopped working. They introduced the keys in the brain and then synchronized. they switched on the ignition and kept it pressed for 10 seconds, but closed it again. The battery has changed. The keys start the car. All functions are normal, one remote control does not work.
I wonder what could be the reason for this? I would be glad if you can help or direct it to someone who understands this.
08.05.2020 13:56 # 2
Have a nice day, Cyber66
I'm sorry we had to address this way because we didn't know your name
If you write down where the transactions take place and we can help you more.
I think that the immobilizer problem has appeared, this promotion is not possible everywhere.
WE WANT TANISMA TOPIC AND DETAILED INFORMATION
08.05.2020 13:56 # 3
sinan-s
307 mi hello ..
08.05.2020 13:56 # 4
Apparently there is no problem with the immobilizer, authorized services are sometimes neglected in such events. You have to ask the keymaker ...
08.05.2020 13:56 # 5
[QUOTE = is DERAN_TUYN]
I THINK THAT I HAVE A BOX UNDER THE STEERING.
IF SURE THERE IS A SITUATION WITH YOUR CAR, THE IMMOBLIZER CANNOT BE PROBLEMS IF THE KITS DO NOT BE PROBLEMS, I WOULD LIKE THE BRAIN ...
08.05.2020 13:56 # 6
Thank you for the answers. My name is Gökhan ...
I fixed the problem. control changed, started working. We can summarize the reason for this as follows
"" "when the controllers are zero, synchronization is only possible once, it is not possible for the second time. It is not possible to understand the wrong one.
I asked many brain teasers in maslak in Istanbul, they could not solve it. Today I went to the Peugeot authorized service in Tekirdağ Çorlu. I can say that it was the most perfect service I have ever seen. It was enchanted that they valued people so much. I have been to Mepa before in Istanbul, I have never stopped after that day. I went to those in Ankara, not in life. I gave up going to the shuttles, but when I saw this place, I would never go anywhere else. I would like to thank everyone who worked in the service in Çorlu. Especially to Mustafa Bey
Even if you are in Istanbul, I think you should go there without feeling cold. I got up from Istanbul and went. When you saw the value given to you in the service, you would not go anywhere else ... They checked my car from the beginning to the end. They took care of the problem. They took care of all of them. I'm so happy right now ...
08.05.2020 13:56 # 7
EmRRmE
Hello friends,
The subject will be grim but I have the same problem.
I have a 2004 Model 307 1.4 HDI vehicle. I came home from work at 20:00 yesterday evening. I was going to work this morning, the remote is not working. The doors never opened, signals did not burn. It doesn't work at all. The classic red led flashes on the lock button on the chest of the vehicle. If it flashed fast, I would think that they forced it at night, but there was no intervention. I also removed the switch case, I guess it doesn't seem like a problem. But I had changed the battery a year ago. I think the battery won't run out for a year. He does not perceive from afar anyway, he was perceived when he went near him It was also a problem, but I did not mind him too much.
I would be glad if you share your ideas if you have them.
NOTE: By the way, the lock on my driver's door did not turn left and right, I didn't think it wouldn't work since I bought it but it did. Smile So I couldn't open the door with the key. I'll show it to the authorized service sometime.
Thanks
08.05.2020 13:56 # 8
I swear, I would say that the battery will not be visible to the left or right and then try it. do you have a spare key.
08.05.2020 13:56 # 9
EmRRmE
No manager is my backup key. When I go in the evening, I will change and look at the battery. I give information
08.05.2020 13:56 # 10
Meanwhile, the key slot w40 is unlocked with frequent disruption until frequent hitches.
08.05.2020 13:56 # 11
Selamiguven
hi peugeot206 HDI. but it showed a malfunction, it unlocks from the control, but it doesn't lock. open from the remote and locked comment with the key. Thanks
08.05.2020 13:56 # 12
bilo131
[QUOTE = Hello!] Hi peugeot206 HDI. but it showed a malfunction, it unlocks from the control, but it doesn't lock. open from the remote and locked comment with the key. Thanks [/ QUOTE]
I know from my old vehicle that the doors were fully closed and when I went to the brain, when I pressed the close button on the remote, it opened again.
that is, even if you close the door completely, the sensor inside the door may be sending false information.
08.05.2020 13:56 # 13
I have two options, either in the fabric or from the doors. There are swiches in the card from the fabric, they can be broken.
08.05.2020 13:56 # 14
YNR
Hello, my writing may be the answer to both Selamigüven and the friend who opened the subject. about 1 month ago, the same situation happened to me ... I could lock it from the remote but I couldn't open it. I also changed the battery of the control, I introduced the vehicle in different ways, but there was no solution. I came to mind the relevant insurance in the fuse box. I checked. fuse was blown. I changed it immediately. the control returned to normal, I locked the vehicle but this time around 10 seconds. then the vehicle turned on the headlights automatically and the lights on the indicators were on. After doing so, the control stopped working again. when the manual turned on, all the lights were off. I've tried 3-4 times like this. then I removed the solid fuse I installed again. This time, the headlights were not turned on, the indicator lights did not come on, the solid fuse coincided with something, the situation was clear. I took the breath in the auto electrician, firstly installed a solid fuse and checked it, he did the same things ... he was suspicious of the tape. (I had the original tape removed and had another tape installed.) The man opened a tape. cables are tangled. He said that the linker had connected wrongly, he disconnected and reconnected it. And as an additional information, he said that the fate of the Peugeot can do whatever strange this vehicle is. No, no sooner, remove the battery and take a 10 min. wait and plug it in again. the brain is resetting itself, recognizing the parts you're wearing. and now it's normal. I mean, I mean.
I say the possibilities,:
- check the corresponding fuse of the lock system
-If you removed the original tape and had another tape installed, have your connections checked. again, if the problem is not resolved, remove the battery terminal and remove it for 10 minutes. then try again, probably the problem will be fixed.
-You also think you closed the doors, but they might not close. sometimes it locks when it doesn't close, open and close a little hard again, and try
-Insurance is very important, by the way, it is a must.
