Remote Control Problem
08.05.2020 21:21 # 1
selcukcolak6161
First of all hello to everyone. I am new among you. My Peugeot Partner 2004 model car remote control does not work. They changed the batteries and checked the control, they said it had to be introduced to the vehicle, but even the master could not introduce it. The left front door lock is broken, I changed it. When closing from the left front door, all the doors are locked, but not through the locking button on the glove and from the remote control. I think there might be an insurance problem, but I don't know which central lock insurance is. Does anyone know about this and can help me?
08.05.2020 21:21 # 2
omerb
Mr. Selim I found something like this. For 206. I think you try too. Maybe it works
206 PROGRAMMING SYNCHRONIZATION - BSI
1. Install the Ignition Key.
2. Press the Small Black button.
3. Turn the ignition ON
4. Press and hold the lock button for 10 seconds.
5. Release the lock button, turn off the ignition, and remove the key.
6. Close all doors and press the lock button 2 times.
NOTE: If PLIPS still does not work, start the vehicle and then CLOSE. Open and close the door and check PLIP again.
08.05.2020 21:21 # 3
First of all, welcome to us. Try what our friend said, will probably be. In addition, information about your vehicle can be found here.
08.05.2020 21:21 # 4
selcukcolak6161
I did exactly, but unfortunately, the door lock key and remote control inside the vehicle don't work 😥
08.05.2020 21:21 # 5
omerb
Sorry, if the locking button inside your vehicle does not work, as you mentioned, the system may not see an insurance problem or one of the doors closed.
I don't know what insurance. But I guess it is written on the cover of the fuse box. Or click the link below, please. There you can look at the insurance numbers that say Lock according to the model of your vehicle. I hope it will do its job. But you have to tell us before the breakdown, let's comment
08.05.2020 21:21 # 6
selcukcolak6161
Unfortunately, there is an insurance scheme for the partners after 2008, 2004. This incident happened to a halt and suddenly the remote control stopped working and then the middle off and on button stopped working. The central lock is working. I checked the key, they said it was solid, they said it should be coded again. Unfortunately, we have not tried every way. Could BSI also be a problem
08.05.2020 21:21 # 7
omerb
now i have met with my electrician friend to leave citroen.
If the door locks do not work from the button inside the vehicle, one of the doors says there is a short circuit. He says we are constantly meeting. Buy one avometer for 30-40 tl. Check all the fuses in the buzzer position, I think. In case of a short circuit, the fuse is already blown. If this fuse has blown, then you need to look at the wiring inside the bellows, through which the cables between the doors pass. If there is anything I can help, I will help.
I refer my friends to Ankara daysan.
08.05.2020 21:21 # 8
selcukcolak6161
Thank you for your answer. I apply what you say and share the result. I hope it works
Peugeot Forums - Peugeot Fan Club © 2025
FromOwner.co.uk — Buy & Sell Directly from Owners in the UK. No dealers. No commissions. Just from owners.
