Remote control does not pull
08.05.2020 17:44 # 1
Turgay_66
Medaba friends 206 in my car, while the remote control was pulling from a distance, now it comes to the door, but I changed it today. Why can I change the battery today? Turgay_66 2013-06-24 21:50:10
08.05.2020 17:44 # 2
Turgay_66
Does anyone know the location of the control receiver in the car?
08.05.2020 17:44 # 3
rolandgarros
the rearview mirror inside the vehicle should be there
08.05.2020 17:44 # 4
Turgay_66
Is it like a little lamp, teacher?
08.05.2020 17:44 # 5
error
First of all, your problem indicates that the controller is taking water and oxidizing is highly probable, the control receiver is not as visible as far as I know ...
08.05.2020 17:44 # 6
Turgay_66
water did not fall, but it happened all of a sudden, it was always parked and after 2-3 steps, it would be locked to the pressure, now it is hard to perceive at the bottom of the door ..
08.05.2020 17:44 # 7
error
These button batteries can surprise people most of the time, when you measure 3 volts, it doesn't guarantee that it is full. error 2013-06-24 23:41:46
08.05.2020 17:44 # 8
Turgay_66
We tried, but it still did not happen, the electrician looked at the control, said no problem, said the problem at the buyer in the car.
08.05.2020 17:44 # 9
Turgay_66
Current.
08.05.2020 17:44 # 10
Turgay_66
It is up to date after a long break. This control started to bother me. I open it forcibly, the doors are new on the battery. How can I clean the controller?
08.05.2020 17:44 # 11
rkalkan
I had the same problem, I would get 1 lira battery to the intern, the problem was solved. Clean the battery bed or try a new battery of good quality
08.05.2020 17:44 # 12
kuscu38
my teacher is a similar problem.
08.05.2020 17:44 # 13
Turgay_66
One experience weekend changing this battery brand :) I press the button 5-6 times to open the door.
08.05.2020 17:44 # 14
pusutr
Teacher, I recommend you to buy sony battery. Something between 5-7 TL. I was doing so, the battery changed, no problem.
08.05.2020 17:44 # 15
Turgay_66
[QUOTE = pusutr] Sir, I recommend you buy sony battery. Something between 5-7 TL. I was doing so, the battery changed, no problem.
[/ QUOTE] Okay, I hope I find the sony one :)
08.05.2020 17:44 # 16
furkanyakar
http://urun.gittigidiyor.com/bilgisayar-tablet/sony-cr2016-5li-lityum-dugme-pil-5-li-kart-92766915
you can also get it here :) get my contribution. I change the battery when the mezil fell. Also note that there are compatible batteries. CR 2016 battery is used in my vehicle.
08.05.2020 17:44 # 17
Turgay_66
[QUOTE = furkanyakar] http://urun.gittigidiyor.com/bilg Bilgisayar-tablet/sony-cr2016-5li-lithium-dugme-pil-5-li-kart-92766915
Thank you, teacher, my key is old, these batteries are probably from the picture above :) Turgay_66 2014-01-07 17:49:12
08.05.2020 17:44 # 18
furkanyakar
[QUOTE = Turgay_66] [QUOTE = furkanyakar] http://urun.gittigidiyor.com/computer-tablet/sony-cr2016-5li-litik-dugme-pil-5-li-kart-92766915
Thank you, teacher, my key is old, these batteries are probably from the picture above :) I ask for it :) [/ QUOTE] same as mine :)
08.05.2020 17:44 # 19
ahmet_bjk
sony ok quality but how do we know if it is original?
08.05.2020 17:44 # 20
pusutr
There are usually watchmakers. Can I see the good and the cheap they show. The packaging is even more robust for the sony battery. 2016 number.
Page : / 2
