Remote control / central lock
18.07.2020 21:33 # 1
murattgr
Hello there. In my 2004 premium vehicle, it neither opens nor closes the doors from the original remote 2 meters from the vehicle, sometimes it is necessary to come closer. Where is the 307's remote control receiver, or does anyone have information for a solution?
19.07.2020 02:49 # 2
muzzy35
In the simplest way, make a battery change, my teacher, then there was a topic previously opened in the forum, they tell about resetting there or something. If there is no room, you have to go to the locksmith and have it done.
19.07.2020 10:56 # 3
murattgr
Thanks, but the battery seems to have a problem with the new detection. I could not find the topic in the forum, unfortunately, it seems like we will face the locksmiths
20.07.2020 09:08 # 4
There may be a problem with the switches on the key, sir, oxide etc. over time. It causes contact and short circuit.
20.07.2020 16:46 # 5
murattgr
It is true, but I opened the key, cleaned it well and inserted it, the battery is considered new. The only annoyance is that it does not detect after 2 meters.
20.07.2020 16:47 # 6
There are test devices in the switches, sir, I need to have a check to see if the signal strength is from the switch or in the vehicle. where are you in ankara hocam.sonerkyl2020-07-20 16:48:17
20.07.2020 19:39 # 7
murattgr
I am in Altındağ district, do I have someone you know to help with this?
08.08.2020 20:50 # 8
heffera
Sa. The same happened to me. It was said here that it partially improved. Put the key on the door and keep it rotated for 3 5 seconds. Do the same with it turned off. Check again the shooting distance heffera2020-08-08 20:51:26
