Remote control
08.05.2020 20:50 # 1
fatih__
Friends The remote control of my 407 1.6 HDI comfort vehicle has to be kept very close to the window for it to work . I measured the values I showed, I got very different values into the liquid. He said to give the new 250 TL new type of control. Is there any place in Istanbul where I can find it more suitable?
08.05.2020 20:50 # 2
pusutr
I think the problem will disappear if the control circuit is cleaned with thinner and solders are refreshed. Go to another keymaker.
08.05.2020 20:50 # 3
ocaliptus
My friend, if it doesn't happen when you clean it up; In the link below, the product costs between 60-70 TL. You can get it from there, and give it 20 TL to copy the control, maximum 100 TL in total. would.
08.05.2020 20:50 # 4
fatih__
[QUOTE = ocaliptus] My friend, if it doesn't happen when you clean it up; In the link below, the product costs between 60-70 TL. You can get it from there, and give it 20 TL to copy the control, maximum 100 TL in total. would.
If the copy is so convenient, I'll get it right away. I had seen it, I was undecided whether to buy it on ali exprest or not.
08.05.2020 20:50 # 5
fatih__
[QUOTE = fatih __] [QUOTE = ocaliptus] My friend, if it doesn't happen when you clean it up; In the link below, the product costs between 60-70 TL. You can get it from there, and give it 20 TL to copy the control, maximum 100 TL in total. would.
I don't know if there is a Peugeot logo on it.
08.05.2020 20:50 # 6
ggitaristt
Aliexpres key comes to 40 liras. If 50 liter coding introduction is available, you can handle this work around 100 liras.
The key-makers are also wonderful. I just wanted more than 100 lira to learn and introduce vehicle code.
08.05.2020 20:50 # 7
fatih__
[QUOTE = ggitaristt] Aliexpresst key comes to 40 liras. If 50 lira is coding introduction, you can handle this work for around 100 liras.
the right one is right, the best is to do as you say ...
08.05.2020 20:50 # 8
ggitaristt
[QUOTE = fatih __] Friends 407 1.6 For the remote control of my HDI comfort device , I need to hold it close to the window so it can be opened. I measured the values I showed, I got very different values into the liquid. He said to give the new 250 TL new type of control. Is there any place in Istanbul where I can find it more suitable? [/ QUOTE]
I have to mention it alone: Investigate the key you will get from China well.
For example, the two-key key I searched and brought out: The control opens, locks, the car works smoothly. But we weren't able to close the windows.
Brother, if you don't want to take risks, you can make keyless keys for 150 liras or something.
ggitaristt 2018-04-19 04:14:52
08.05.2020 20:50 # 9
fatih__
[QUOTE = ggitaristt] [QUOTE = fatih __] Friends 407 1.6 For the remote control of my HDI comfort device , I have to hold it close to the window to open it. I measured the values I showed, I got very different values into the liquid. He said to give the new 250 TL new type of control. Is there any place in Istanbul where I can find it more suitable? [/ QUOTE]
Thank you very much for sharing such a detail ... We have to investigate the keyers. I went to one and said 250 TL. Let me visit the others over the weekend.
08.05.2020 20:50 # 10
maximusti
alternative cleaning method;
pure alcohol or cellosic thinner.
take out the board of the controller, throw it in thinner or alcohol, and remove it shortly,
Brush it slowly with an old toothbrush, it will remove all oxidation inside.
Install a new battery and try it out.
We used this process on all phone motherboards when I was repairing mobile phones.
If you request from a phone with a technical service nearby, it will do this.
08.05.2020 20:50 # 11
ocaliptus
Keys that are 30-40 lira on Aliexpress, just the container of the key. There is no electronic kit and battery inside. The key in the link I provided is with both the box, the electronic kit and the battery. Pay attention to this.!
08.05.2020 20:50 # 12
necmettinn
If you leave the control circuit you mentioned in a jar full of rice embedded in the rice, the rice will draw the water that has escaped into it. Or you can try to dry it with a hair dryer. After making sure that it is dry, it will be useful to renew the solders because oxidation will occur in the future, even if it is not in the soldering points that touch the water, and it will be a problem again. I think that if the last cleaning is done with alcohol and toothbrush after solder renewal, the problem will be eliminated.
08.05.2020 20:50 # 13
fatih__
[QUOTE = necmettinn] If you keep the control circuit mentioned in a jar filled with rice in a jar full of rice, the rice will draw the water that escapes into it. Or you can try to dry it with a hair dryer. After making sure that it is dry, it will be useful to renew the solders because oxidation will occur in the future, even if it is not in the soldering points that touch the water, and it will be a problem again. I think that if the last cleaning is done with alcohol and toothbrush after solder renewal, the problem will be eliminated. [/ QUOTE]
Thank you very much for your valuable information ...
08.05.2020 20:50 # 14
ggitaristt
[QUOTE = ocaliptus] Keys that are 30-40 lira on Aliexpress, only the container of the key. There is no electronic kit and battery inside. The key in the link I provided is with both the box, the electronic kit and the battery. Pay attention to this.! [/ QUOTE]
I bought the empty container for 5 liras, I bought the key 35 lira fully working.
08.05.2020 20:50 # 15
fatih__
Friends, I took it to another keymaker, repair 50 TL, new 180 TL, the penny did not go down.
