relay
08.05.2020 16:23 # 1
by_imp
What is a relay friends or how many relays do you have?
08.05.2020 16:24 # 2
voodoo
Let me explain the electronic circuit element called the role to you sole, it is a key that uses the switched electromagnetic field as a trigger and switches it ... developed by using it in various ways ... electromechanical role, reed role, various time roles ... etc ..
08.05.2020 16:24 # 3
by_imp
I understand it is just relay
08.05.2020 16:24 # 4
Muhammet CAKIR
If you need to give an example of the purpose of use to the role, you will connect a fog light to your vehicle. There is no fog light in the front. There is a fog light in the back. to get it from the aquarium.
Muhammet ÇAKIR 2011-11-25 23:28:05
08.05.2020 16:24 # 5
djchaos
I think the lpg cars are also installed, remember the relay is wrong ??
08.05.2020 16:24 # 6
Muhammet CAKIR
[QUOTE = djchaos] I think it is also installed on LPG vehicles, remember the relay is wrong? There is a delayed rotary signal roles, it closes and hurts, some of them wear the role of the injected car, the car cuts off the gas :) some of them wear it, the horn resonates, there are different tasks.
08.05.2020 16:24 # 7
by_imp
Well, does this relay have a connection with the car not eating gas and gas cutting and gas pump.
08.05.2020 16:24 # 8
Muhammet CAKIR
[QUOTE = by_imp] Well, does this relay have a connection with the car not eating gas and gas is interrupted with gas pump [/ QUOTE] I do not think it will not work if it does not work in the role connected to the gas. Clean
08.05.2020 16:24 # 9
by_imp
No lpg teacher, the vehicle is connected to the computer, so I don't know, they made an expense, they said to me that they needed to change the gas pump and the role.
08.05.2020 16:24 # 10
by_imp
In fact, the problem is that the car goes bad until 2 revs. The engine sound comes after the muffled tour 2. After I got it from the service today, I noticed that it was working badly at idle.
08.05.2020 16:24 # 11
Ucyuzalti
I don't understand what the pump has to do with kicking? As soon as the pump starts or runs, if I know gasoline to the vehicle, there is no problem in the pump. If the vehicle is misfire & nbsp; It seems silly to me that if the problem is the cheapest, the ignition system is going to go to the parts affecting the engine such as the air filter, and they go directly to the pump. I wish you had a lpg in your vehicle, let's try it right away.
08.05.2020 16:24 # 12
Ucyuzalti
This is the Turkish intelligence to make the cutter with the role & nbsp; "Clap"
08.05.2020 16:24 # 13
Ucyuzalti
I have not read this message. Lacklessness in the lower cycle:
Ignition system
air filter
Throttle dirt
Exhaust system (if a large boiler is installed, the performance will drop at lower revs) The problem would increase at high speed.
08.05.2020 16:24 # 14
by_imp
well, gaziantepte
gazikent forensic pejo authorized service and agency
08.05.2020 16:24 # 15
by_imp
I like this situation, I think the fuel has decreased, I think I have traveled 100 km.
