Related to Plates
08.05.2020 19:18 # 1
samet206
Sa friends had a wear on my plates, I had opened a subject before, I changed it from traffic, I renewed it.Font as well, I made a nice app font, sealed the process is okay. I said it did not fit the plate, I could not cut it, they reacted as writers of punishment.
Now my question is, is there any punishment when I cut these edges and put the plate on the plate?
In the second one, what do I cut with my own means and I wonder if I will throw the paint on the plate or damage the holagram, and I will be treated accordingly when the edges are cut?
08.05.2020 19:18 # 2
oktan24
Instead of cutting, you can wipe the black areas on the edges of the plate with thinner. You can remove the plate and stick the plate with silicone.
08.05.2020 19:18 # 3
samet206
Master, if I was a flat piece, I would have done it anyway, thanks anyway. I made this shiny plate made of plates. It does not sit without cutting the black edges on the plates. I cut it in such a way that I could sit it in the plate, I couldn't assemble it because it would get a little silicon or rain.
The aforementioned plate.
08.05.2020 19:18 # 4
madblueblacksea
The plate is beautiful. You carved a separate plate for the protrusion and glued my superior
08.05.2020 19:18 # 5
samet206
[QUOTE = madblueblacksea] The plate is beautiful. You carved a separate plate for the protrusion and glued my superior [/ QUOTE]
Thank you. They are probably doing as you said, but I made it, so I got it ready. I don't know about the workmanship of the product.
08.05.2020 19:18 # 6
oktan24
[QUOTE = samet206] If I was to be a master flat, I would do it anyway, thanks anyway. I made this shiny plate made of plates, it does not sit on the plates without cutting the black edges. I cut the plate in the most smooth way possible in the tinner, I put it in the plate, I couldn't assemble it because it would get a little silicon or rain.
My beautiful teacher, use the plate in Good Days
08.05.2020 19:18 # 7
samet206
Thanks guys. Yamanz today the setback went wrong, I took care of the back side and it was just as I wanted it. Enforcement was enough to finish the plate. It was obvious that we could not use the plate anymore. Being different is disrupting my morel, but I do not think that it will be very absent, it does not need more adventure, because it was enough for me :) As a result, something different came out, we both cleaned our plates and got rid of the plates that the mechanics wore.
