Redline
08.05.2020 15:46 # 1
kaderim@61
friends, my car redline does not give a loud voice, it sounds slower I wonder if some vehicles are like this or if there is a problem, I have paid attention to most vehicles.
08.05.2020 15:46 # 2
kaderim@61
friends nobody knows about the limiter (gas cutter)
08.05.2020 15:46 # 3
werty
it is slow in some vehicles.
08.05.2020 15:46 # 4
brother somebody will answer ... nowadays, no holiday anyway .. no cecolide is 1-2 days ... most likely my text is knowledgeable about this ... let's see a little wait ...
08.05.2020 15:46 # 5
metin
ersin brother (:
I am not as good as I am, I will not collapse, but the gas cutter is going on in series. Bene is more about rolenti cycle than gas cutter. If it falls normally late, it is normal to cut it slowly in the gas cutter.
but friends who use 106 respond better. If there is a serial cut in 106, then there is a problem.
08.05.2020 15:46 # 6
106_arts
The sound of the sound comes out or the cutter cuts slowly where it will cut fast Do you have lpg
08.05.2020 15:46 # 7
kaderim@61
slowly cuts no sound, no problem in the vehicle
08.05.2020 15:46 # 8
kaderim@61
actual
08.05.2020 15:46 # 9
kaderim@61
actual
08.05.2020 15:46 # 10
eren8er
You will go and listen to a beautiful master.
08.05.2020 15:46 # 11
[QUOTE = eren8er] you will go to a beautiful master, you will listen to the sound .. if you have a problem, it will be taken care of or you will not continue .. [/ QUOTE]
+ 999 Thumbs Up
08.05.2020 15:46 # 12
In my opinion, a situation that will never be ignored. I don't think the cutter will change whether it's LPG or not.
It is also harmful to run the tool in the cutter, especially when it is idle, to insert it into the cutter. Why don't you get it done with something like that ...
Also, the cutting speed of each vehicle is not the same. Does it matter if it cuts fast or cuts slowly?
Ecu makes this event. I do not think any evening will change this event ...
08.05.2020 15:46 # 13
kaderim@61
I wondered why it was so fast in most vehicles. Sırıtma
08.05.2020 15:46 # 14
[QUOTE = my destiny @ 61] I wondered why it was so fast in most vehicles. Sırıtma [/ QUOTE]
Whatever the structure of the engine is, you cannot change it. All of them are different to understand ...
If you continue to do so, you will quickly get your engine off.
08.05.2020 15:46 # 15
kaderim@61
No, I don't want to do it, but I just know the sound.
08.05.2020 15:46 # 16
Another subject, are you hungry? Keep going from here.
In response to that problem: If the vehicle cannot be accelerated in the revolver, you insist that if you drive it in this period, the cover will be experienced when you say you don't cut off ... Göz Kırpma
As soon as you have to do, the gear shifts. Actually it is to do this without inserting it into the cutter ...
the cecol 2011-07-21 11:41:55
08.05.2020 15:46 # 17
kaderim@61
thank you for the information he gave Gülme
